RHOX Yamaha G14, G16, G19 Golf Cart 6" Spindle Lift Kit 95-02 Electric or Gas Logo
Ralph Torres Posted on Aug 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why don't I get power to the motor on my Golf cart and how can I fix it.
What did I do wrong? After installing six new 6V batteries in series on my 1999 Yamaha golf cart, full power is fine up to the selenoid, but not to the shifter or motor after that. Upon plugging in my charger to the cart, as requiered, it blew out the Charger fuse. No issues with Cart until the battery replacement. Installed correctly in series for 36Volts total output. Can you help? Ralph
FastHarley
Level 3:
  • Master 761 Answers
  • Posted on Nov 22, 2014
FastHarley
Master
Level 3:
Answers
761
Questions
Helped
360491
Points
2528
BuggiesGoneWild has all types of poems. Please visit their website. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
My golf cart has six, 6 volt batteries connected in a chain, positive to negative throughout. Can I connect an auxiliary light of some type to this power source?
the cart is wired for 36 volts operation so you would need a 36 volt bulb
or
you could put the wiring for a 12 volt bub across the terminals of 2 batteries so the negative wire will be on a negative terminal of the first battery and a fused positive wire will be on the positive of the second battery
the batteries are connected in series so the sum total of the voltage is the sum of all of the batteries
by selecting 2 batteries in series you are using the sum voltage of 2 batteries
Nov 24, 2017 • Golf
How can I Speed up my 2004 Yamaha 36 v golf cart short of changing motor
If you are getting full voltage to the motor and that is the best you can do, then you have no recourse other than to change the motor.
Mar 31, 2017 • V Golf Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 • Golf
Why doesn't our Melex golf cart start after replacing batteries.
sounds like you have either a relay or computer that is bad, needs to be serviced
Nov 30, 2015 • Golf
1helpful
Pleasecontact golf cart Kings out of Austin Texas. They will be more than glad to help you with this problem that you are encountering. Their Tek savvy is always free. Please be patient as so many people are always asking questions. But you can't beat free. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
The solenoid should click when cart is switched on.When it clicks on it sends the full voltage to the motor controller and motor.Check the voltage going to the solenoid with a volt meter on the thin wires.
After installing six new 6V batteries in series on my 1999 Yamaha G16E golf cart, full power is fine up to the selenoid. nopower to the shifter or motor after that. Upon plugging in my charger to the cart,...
Verify series battery wiring. The main positive wire which goes to the solenoid should be on a positive battery post, that will be your main positive. Then from there we go series to all the rest of the batteries until we are left with a negative battery post, that will be your main negative. Make sure your charger wires are connected to the mains.
1helpful
Club car golf cart
If it was me, if it gets hot, that's usually a sign that the juice if flowing through it wrong. Sounds like you've got something hooked up backwards. or grounded out to something else. Check everything again. Get help from a professional if that doesn't fix it.
Nov 28, 2013 • Golf
How do i wire my golf cart for one light and one horne 6 volt batterys 36 volt system
The batteries are connected in series (6V + 6V+ 6V +6V +6V +6V), Select only two batteries (CONNECTED TO EACH OTHER in series FROM POSITIVE TO NEGATIVE (last two batteries preferred) and run two wires (one black one red) from the positive (red) and the negative (black). purchase two switches one MOMENTARY PUSH BUTTON AND ONE TOGGLE. Split the two wires by ADDING another length to the middle of each wire respectively Add the switching devices by connecting the red wire to one of the terminals. The other terminal will then receive Another length (red) to be the connected the same way to the horn (push button switch) The black wires (ground) are to be connected to the other terminal of the horn and light. NOTE: it is advisable to add a 15A in line fuse to the red wire near the battery.
22helpful
Trying to hook 12 volt lights to a 36 volt golf cart
The exact answer depends on what battery voltage you have but this hint will get you going.
Assuming you have 3 12v batteries, just wire to the first battery + - and you'll have 12 v. If you have 6 6v batteries, wire to the first + and the second -. If you have a voltage meter, you can verify the voltage of my suggestion.
This will work for lights and other resistance circuits but not for sensitive items like radios.
Golf cart batteries are series wired to get the higher voltage.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Top RHOX Golf Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
vince
Are you a RHOX Golf Expert? Answer questions, earn points and help others
