SOURCE: I was giving a 87
I hope this help's you:
Website: www.popupportal.com
Top of the screen : Owner's Manuals, click on it and scroll down to Coleman, click on and download your file.
Have a nice "Summer"
SOURCE: Coleman stove, model 412-5621, will
disassemble the pump by removing the c-shaped ring aroudn the metal cap. a flathead screwdriver will work to pry off the ring.
pull out the pump assembly. The end is probably a old dried out leather ring. It needs oil (car motor oil shoudl be fine) and it needs to make a tight seal.
if it is too loose, it might be possible to press it out to make it wider. If not, it needs to be replaced. The pump assembly is about 8 dollars at many stores.
SOURCE: coleman instastart propane stove regulator wanted
Check to see if Coleman has an attachment to replace the regulator, so that you can use a five gallon cylinder with your stove and your own regulator.
SOURCE: Manual for a Coleman Forced Air Furnace manual
If you haven't already tried Coleman customer support, try Google. You can find owner's manuals for all kinds of things. good luck, John
SOURCE: lost manual 6250 watt coleman generator what oil to use and were
If it has the Tecumseh engine..
Above 40°F Straight SAE 30W
Below 40°F down to -20°F Straight SAE 10W or SAE 5W30 or
Below 40°F down to -40° SAE 0W30 Synthetic
Using multigrade oils above 32°F will increase your oil consumption. SAE 10W40 is not recommended.
Per the manual, all the oils should be marked A.P.I. Service SL/SJ, but you may have to use something to a newer standard. E.G.: Service SM.
The oil sump capacity is 1-5/8 U.S. Pints or 0.76 Liters.
Hope this helps.
