I have a Huminbird fishfinder 525 and the depth keeps reading 700-800 feet. I have readjusted the angle numerous times and get very little change. I have reset to factor settings and the test mode indicagtes it passed all the test. any suggestions on how to repair or determine if it is the unit or the transducer?
SOURCE: My 570 quit showing the depth and continues to
I had the same problem. It was the transducer.
SOURCE: the depth digital read out
If you purchased it new, bring it back for an exchange. The transducer is what reads the depth, and is not operating correctly. I'm assuming you tried to adjust the depth tolerance in the menu options and also disconnected battery power and reconnected.
SOURCE: Unit wouldn't recognise the transducer. CS told me
It is hard to say. If you know someone that has a unit simular to yours just slide it on to there mounting system and then you will be able to tell if it is the unit or the transducer.
Joby @ Humminbird
SOURCE: Humminbird 525 concerns , I bought a new 525 last
Is the head unit mounted near a compass, other GPS or antenna? This seems like a classic magnetic interference. Since the heads were swapped and it still functioned the same. Has the transducer been mounted with the template provided? If not, this could also compound the issue.
