Kingston DataTraveler 101 G2 Logo
A
Anonymous Posted on Aug 15, 2014
Volume label VOLUME LADEL
Fred Block
Level 2:
  • Expert 289 Answers
  • Posted on Nov 26, 2014
Fred Block
Expert
Level 2:
Answers
289
Questions
Helped
166303
Points
608
Put your drive into a USB port; right click on that drive after it appears in My Computer and select Properties. On the "General" tab, change the label text in the field at the top and click OK to save your change. You have a limit of 11 characters and stick with letters and numbers (spaces are not allowed but you can use an underscore character "_" instead or a space character).
3answers
I am converting Fat to NTFS convert l:/fs:ntfs the drive is 2gb what do i enter for the volume label for that drive
You need to locate the current volume label on the drive.
The easiest way to do this is from the command prompt, you type in vol(space) then the drive letter you are converting & press enter. It will then tell you the volume name, and then on the second line the serial number for the drive.
Why is volume label for the C drive is OS in stead of system when looking up volume label?
If I understand you correctly, you are asking why the volume label for C Drive is called "OS" instead of "System". Is this correct?
Volume icon missing
Which operating system ??
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer.
Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel.
Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel.
Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
1helpful
2answers
Memory card 1GB volume label
My Computer. Right click Format > Volume Label.
My Computer. Right click Properties > Volume Label.
Start > Run / Search. Type cmd ENTER. Type label x: [name] x being the drive letter.
My harddrives cd image partition is readable but another 1tera byte part is not getting detectd. please help
Sometimes my external drive fails to mount. What I do to force it is follow these steps:
Click start and open up a command line window. Either find it in the Accessories folder or type cmd at the search.
In the cmd window, type 'diskpart'. A new command window might pop up. In the new window, or the same one if a new one doesn't pop up, then type 'list volume'. It will list a number of volumes on the system in the form:
Volume ## Ltr Label FS Type Size Status Info.
Find your hard drive in this list and note the volume number. I usually find the hard drive by comparing Sizes, but it should also show your hard drive's name under Label.
Next type 'select volume x' where x is the volume number for your volume. So for instance if your hd happened to be listed as Volume 3, you would type 'select volume 3'.
Now, type 'assign letter=G' or whatever letter you want your volume to be. Once you've done this, your volume should be mounted and you should be able to access your drive normally.
1helpful
Looking for volume control
Take a look at this:
Labelled No.8 = Volume Up button.
Labelled No.9 = Volume Down button.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Cannot format octagon veridisk T118 usb
Try this
Microsoft Windows 95, 98, ME syntax
Formats a disk for use with MS-DOS.
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B | /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B | /S] [/C]
/V[:label] Specifies the volume label. /Q Performs a quick format. /F:size Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88). /B Allocates space on the formatted disk for system files. /S Copies system files to the formatted disk. /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. /C Tests clusters that are currently marked "bad." Microsoft Windows 2000 and Windows XP syntax
Formats a disk for use with Windows 2000.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/A:size] [/C] [/X]
FORMAT volume [/V:label] [/Q] [/F:size]
FORMAT volume [/V:label] [/Q] [/T:tracks /N:sectors]
FORMAT volume [/V:label] [/Q] [/1] [/4]
FORMAT volume [/Q] [/1] [/4] [/8]
volume Specifies the drive letter (followed by a colon), mount point, or volume name. /FS:filesystem Specifies the type of the file system (FAT, FAT32, or NTFS). /V:label Specifies the volume label. /Q Performs a quick format. /C Files created on the new volume will be compressed by default. /X Forces the volume to dismount first if necessary. All opened handles to the volume would no longer be valid. /A:size Overrides the default allocation unit size. Default settings are strongly recommended for general use.
NTFS supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K.
FAT supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes).
FAT32 supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes). Note that the FAT and FAT32 files systems impose the below restrictions on the number of clusters on a volume:
FAT: Number of clusters <= 65526 FAT32: 65526 < Number of clusters < 268435446
Format will immediately stop processing if it decides that the above requirements cannot be met using the specified cluster size.
NTFS compression is not supported for allocation unit sizes above 4096.
/F:size Specifies the size of the floppy disk to format (160,
180, 320, 360, 640, 720, 1.2, 1.23, 1.44, 2.88, or 20.8). /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. Microsoft Windows 2000 and Windows XP recovery console syntax
format [drive:] [/q] [/fs:file-system]
drive: Specifies the drive to format. /q Performs a quick format. /fs:file-system Specifies the file system to use (FAT, FAT32, or NTFS) Examples
When using the format command, remember all information on the drive you wish to format will be completely erased.
format a:
Would erase all the contents off a disk. Commonly used on a diskette that has not been formatted or on a diskette you wish to erase.
format a: /q
Quickly erases all the contents of a floppy diskette. Commonly used to quickly erase all information on the diskette.
format c:
This would erase all the contents of your C: hard disk drive. In other words, unless you wish to erase all your computer's information, this command should not be done unless you're planning to start over.
Or
Right click My Computer-->Manage-->then go to Disk Management
and select the to format right-click it and click format. Thats it Your drive will format and You can also choose in which file system you want to format your drive.
For further help or to thank me mail me on my email [email protected]
2helpful
What does volume label mean?
When a hard drive has been formatted, the user can give the storage space created a name: that is the volume label.
For example, on a PC computer the main hard drive is recognized as C, the CD-Player as D: and if a USB key is plugged in it gets drive letter E:
In addition to these Drive letters, the user may choose to give a more "meaningful " name to one or all drives. This additional name is the volume label. It is usually optional on PCs.
You digital media player is also a hard drive and the storage space on the media player (where you store your files, songs) can have a NAME or volume label.
2helpful
2answers
I dont know wat to put in volume label cause i cannot formta it!
you do not require to put anything in the volume label infact there must be a check box under the volume lable box uncheck it and try.
if the problem persists simply put any label keeping in mind it dose not match your existing drive label.
thank you.
5helpful
3answers
What's volume label
when i go to format my mp3 it say windows can not complete format plz help.
Top Kingston Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
