Check
engine light comes on and off, these are indication that there is some
error code stored in your vehicles ECM. The engine module computer
needs to be scanned. These will give the code and as per the error code the
further problem can be detected and confirmed. The engine light
indicator blinks or remains steady on dash when engine computer
noticed any problem with any engine electrically operated components.
For
more help, I suggest you to refer the help links provided below. These will let
you know more about which areas to look, check, when there is engine light
coming up on dash panel.
Click
the link below: -------
CHECK ENGINE LIGHT
http://alltypesofpartsreplacing.blogspot.com/2012/12/check-engine-lightengine-warning-light.html
Check Engine Light Reset Procedure?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-reset-procedure.html
These will help.
Thanks.
Check
For
Click
http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
http://howtobyme.blogspot.in/2012/02/check-power-train-message-with-orange.html
http://whatisbyme.blogspot.in/2012/05/2007-toyota-highlander-hybrid-yellow.html
http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
http://schematicsdiagram.blogspot.com/2011/12/vehicle-smog-test-failed-due-to-no.html
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-check-engine-light-flashes.html
These
details will help.
Thanks.
Toyota Camry Check engine light flashes while
driving?
----------1999 Toyota Tacoma: Check Engine Light
Read Code P0171?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-tacoma-check-engine-light.html
2007 Toyota Highlander Hybrid: Yellow Check
Engine Light ON dash?
--------Check engine light with codes P2195 and
P2197?
---------Car Runs Fine But Check Engine light is ON?
----------After replacing throttle body the Check engine light starts
blinking?
http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
---------OBD Code is cleared but check engine light
will not RESET?
--------These will help.Thanks.
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
light starts blinking?
This details will help you.Thanks.
