Apple iPad (16 GB) WiFi Tablet PC Logo
A
Anonymous Posted on Aug 12, 2014
How reset ipad passcode
My password has been changed on wireless conection how do i chcnge it on my ipad
Sanjugargay
Level 2:
New Friend:
  • Expert 48 Answers
  • Posted on Aug 12, 2014
Sanjugargay
Expert
Level 2:
New Friend:
Answers
48
Questions
0
Helped
18897
Points
124
  1. Start the iPad
  2. Tap on the Settings app
  3. Tap on the Wi-Fi category
  4. Choose a Network
  5. Once you Tap on a network name, it will try to connect to it. If the network is using wireless encryption, though, you will be presented with a screen asking you to enter the wireless encryption password.
How to connect an iPad to Wireless or Wi Fi network
1 Related Answer
Anonymous
  • 32 Answers
  • Posted on Aug 27, 2012
SOURCE: How do i reset my locked iPad?
if u r having software of that i pad u can use it with datacable and then format it
I forgot my ipad passcode and never synced to a computer
I would just take it to a instore mobile phone repair man/or lady usually chinese are great at what they do not expensive .
1helpful
Is it possible that if I have forgotten my Icloud passcode it can be deleted?
it can't be deleted but you can change it using your laptop or desktop and browse appleid.apple.com then follow instructions to reset your password.
Reset apple ipad passcode
There are different ways to reset Apple iPad passcode such as with iTunes. Follow below simple steps to reach the aim.
If Find My iPhone app is on, you can try the socond method: Reset iPhone password with iCloud Find My iPhone. The detailed steps are shown as below.
Step 1. Go to icloud.com and log in with your Apple ID and password on your computer.
Step 2. Click Find My iPhone. Then click All Devices at the top of your browser window.
Step 3. Select your iPhone from all the devices listed. Click Erase iPhone to erase your iPhone along with its passcode.
Step 4. Use the Setup Assistant on your device to restore the most recent backup of your device.
After the restoration process is finished, your passcode will be erased and all your data will be restored from your iCloud backup. You will now be able to access your iPhone without any passcode.
For more methods, check: How to Reset Password on iPhone
1helpful
2answers
I can't unlock my Ipad, it won't accept my password, how can i change my password
If you have synced your iPad with iTunes before you forget your password, you can reset your iPad by using iTunes without losing data. Through iTunes, you can restore your iPad from the last backup and remove the passcode from your locked tablet while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPad Passcode with Recovery Mode section below.
Step 1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
Step 2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPad without any passcode. And you can set your new password on iPad.
http://www.leawo.org/tutorial/how-to-reset-password-on-iphone.html
How can i get passcode
Hi Donald. Do you forget the passcode?
If you have synced your iPad with iTunes before you forget your iPad password, you can reset your iPad by using iTunes without losing data. Through iTunes, you can restore your iPad from the last backup and remove the passcode from your locked iPad while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPad Passcode with Recovery Mode section below. The following steps will show you how to reset iPad password with iTunes.
  4. In the Summary window, you can see the option "Restore iPad". Click it and follow prompts to choose the latest iTunes backup to restore your iPad.
2answers
Unlock passcode ipad
Did you have find my iPhone turned on? If you did you could have erased your iPad that would remove the pass code that is on there now
I forgot my password, and disabled my ipad mini , and need to get back into it
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
4helpful
3answers
My ipad is disabled how do i fix it
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
How do i reset the passcode
If you forgot or lost your password for your iPad, you'll have to restore the iPad. Plug the iPad into your computer using the cable, and open iTunes. Click on your iPad in left pane and click the 'Summary' tab. Click 'Restore.' This will wipe all data from your iPad and effectively reset the device to factory settings, but it's the only way to reset the passcode.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
