As long as your brother isn't ex-directory and has a British Telecom landline, his phone number can be looked up here. Fixya does NOT post phone numbers.
https://www.thephonebook.bt.com
Search The Phone Book from BT to find contact details of businesses and people across the UK, or UK and country dialling codes.
In order to sync a Palm device with other applications, including Outlook on Windows, or Apple's iCal and Address Book on the Mac, users can install Palm conduits, which divert data headed to Palm Desktop to an alternative selection of apps on the computer instead.
hi there
now i have an idea to fix this problem , you need to find the manual catalog if its still with you or download it from the main website and then try to see the steps in the manual that gose to the languge section step by step by the right order cause you cant read the chainees,i done it once i change my phone to turkey and it worked with me.
good luck.
FIND THE SETTINGS BY BORROWING,BUYING OR WHATEVER A ENGILSH TO CHINESE DICTIONARY AND TRY TO FIND THE LANGUAGE SETTINGS OR JUST FIND A PLUGIN FOR YOUR MP3/4 TO ENABLE ENGLISH LANGUAGE
Completing addresses when addressing an email works a bit different
as Outlook doesn’t have an AutoComplete feature but has an AutoSuggest
feature a Check Names feature instead.
The subtle difference between the two is that the AutoSuggest
feature doesn’t have a direct relation to your Contacts folder or other
address lists configured in your Address Book. Instead, AutoSuggest
uses a cache which contains a list of addresses that you’ve previously
used.
Outlook also has another feature which is similar to AutoComplete; Check Names.
Check Names can work interactively and by default also works as a background process.
Check Names – Interactive To use Check Names interactively,
you type part of the name or address and then press the Check Names
button on the Toolbar or Ribbon or press its keyboard shortcut (for
most localized versions this is CTRL+K). This will search in your
Address Book for that part of the name. If only a single address is
resolved, it will directly show this in the To-field (or CC or BCC
field). If multiple addresses are found, then it will prompt you with a
dialog to select the correct address from.
Check Names – Background When you only type part of a name or
address and then switch to the message body, Check Names will perform a
background search in your Address Book. If only a single address is
resolved, it will autocomplete the address for you. If multiple
addresses are found, it will underline the address with a red scribble
line.
When you press the Send button while an address is not fully resolved, you’ll get prompted to select the correct address.
To turn of this background feature of Check Names go to; Tools-> Options…-> E-mail Options…-> Advanced E-mail Options-> disable option: Automatic name checking
You can manually enter addresses by going to Machine Status> Tools. Add Address Book Entry and entering single entries there. Youcan also upload a .csv by browsing into the copier via the IP and going to Proprties> Services> Internet Messaging> E-mail> Public Address Book and Mapping the existing address book to your computer. It will be in a Comma Seperated Value format that can be Modified in Excel and reuploaded in the same area, but instead of mapping existing address book, Upload .CSV file to Address Book and exiting.
You should provide the english version of the installer. maybe you can download that if your win2003 server is license in microsoft. it is probably sure that the version of the installer is chinese language.
