SOURCE: i have paslode finishing nail gun , i cleaned it, not working now
The smoking is normal for a few times after cleaning ,but you might have put to much oil drops in chamber and piston chamber is getting a "vapor lock". Try recleaning with degreaser. Also have you forgotten to set the depth gauge at front of nose.
Please Rate jj505 Thanks
SOURCE: Firing pin not retracting far enough to allow nails forward
Yes,this is a common "mis fire" by Pasilode. I own the 16p Framer and the Angle nailer and I never get it from the Framer but I do get it seldom from Trim Gun,nothing you can do ,its just a misfire.
Please rate jj505
SOURCE: CLEANED NAIL GUN EVERY THING SOUNDS OK BUT NOT FIRING CHANGED GAS
Pull the top off and clean the spark plug with a carb cleaner spray.
Check gas canister ...make sure it's not empty..
Do you get a green blinking light on the unit?
K
SOURCE: When I fire my im250 the firing pin often does not retract
Using a wire "toothbrush" size brush, clean the track in front of the gun where the pin slides - where the nail groove is. **** particles from the nails and the plating from the nails sluffs off fouling the path and causes the pin to stick. After several cleanings of my gun, I noticed that this brushing of the track the firing pin follows keeps it operating for several days without the problem recurring!
SOURCE: my paslode f 16 nail gun wont fire nails,new gas.
i found this happening to me and i oiled (light oil like 3 in 1) the driver (hammer) in the tip. that way it could retract and drive the next brad.
