HOW DO YOU RETREIVE THE HINGE BRACKETS FROM INSIDE THE LEISURE GOURMET 60 CHASIS.
SOURCE: Belling DB3 Main oven door falling off its hinges
The same thing is happening with my oven. I have found a web page which sells the parts and removing the door and replacing the hinge would be easy enough. The design of the door however, may mean the problem just happens again.
http://www.espares.co.uk/part/cookers-and-hobs/belling/db3/p/1092/154/0/547474/550894/door-hinge.html
SOURCE: Oven Door Hinge is broken Kitchenaid KERC507 range
at about any appliance parts store in you area you just need your model and serial number there are links on this site kitchenaide is made by whirlpool so they can help or if you want to do it online this is good http://www.repairclinic.com/SmartSearch/smartsearch.aspx
SOURCE: Changing the main hinges on the oven door
Contact the britannia Service team on 01253471111 option 3. Someone there will be able to talk you through or they could do it for you.
SOURCE: Teba Mini Kitchen (Oven &
Did anyone ever figure out how to fix the hinge problem? My girlfriend has one of these ovens and the right side hinge is loose but i'm unsure of how to tighten it. The door won't close all the way, so it takes forever to cook anything.
[email protected]
Thanks!
SOURCE: hinge, oven door #822144
Pull up on the door to remove it from the hinges.
Remove the pan drawer on the bottom. Remove the spring from the hinge to be replaced. Remove the hinge mounting screws. Remove the hinge.
Reverse this process to install the new hinge.
