The machine says "duplex unit not set"
SOURCE: Lanier ld145 duplex error
The duplex is on the right hand side of the copier (external unit from the main print engine). You firstly need to check for a jam inside the unit, open the unit away from the copier and there will be a blue tab to access further beyond the black plates. Also make sure the unit is seated correctly and plugged in (Turn off unplug and plug back in, this will also reboot the machine). This is customer recoverable error so the reboot should fix it
SOURCE: I have a Lanier 5245. I am getting an error when
Your duplex is the big box on the right side of the machine push the back side shut against the machine and try again
SOURCE: Trying to make 2 - 2 copies. Machine has message
I don't know who advised you before, but...don't start a new link by yelling at people, and.....
2: be thankful for any FREE advice you receive.
3: Ask politely for further advice
4: Learn the basics of your OWN copier.
5: download a user manual from the ricoh website (it's readily available). and look up "duplex"
...here's a hint......guess what that big square box is on the right side??
