Fuel will not pull from tank into bulb
There are 2 fuel lines going into the back of the primer bulb. One line goes from the back of the bulb into the fuel tank, and the other goes from the back of the bulb into the carburetor. I believe that the line that goes into the fuel tank has disconnected from the back of the bulb. You will need to remove the bulb, find the line that dropped off of the bulb and into the tank, and reconnect the line to the back of the bulb.
SOURCE: Missing T piece from primer bulb to carburator
Sears has replacement parts and so do the OSH stores. If there's no store close, check with a local lawnmower shop and I'm sure they've got lots of replacement parts.
