Samsung UE40B7020 40 in. LED TV Logo
A
Anonymous Posted on Jul 25, 2014
Samsung how to connect a vcr
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Jul 25, 2014
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008070
Points
237762
Refer its user manual for connection details. Electro help
How do I connect the VCR to a new Samsung TV
If both the VCR and TV have HDMI connectors its as simple as connecting an HDMI cable from the VCR HDMI output to an HDMI input on the TV.
You can google HDMI connectors if you don't know what it looks like.
How do i connect my samsung TV to my VCR
I couldn't find any information on the Samsung TV on the web. So I have no idea what the connections are. As you haven't stated what type the VCR is or the connections it has, I and others on Fixya are working in the dark!
2answers
Samsung DVD-V3650 DVD Player / VCR Combo no sound when connected via component cable
Component connections between your DVD player and TV (they will be colored red, blue, and green) carry video only. You will need to connect two more cables for left and right audio channels. The connectors for these audio cables will be colored white and red for left and white respectively.
2answers
I would like to know how to connect a dvd player through my samsung vcr the inputs in the back i am not familiar with there are two sets of yellow white and red connections with one side for output and...
Connect from dvd OUT to vcr IN
The yellow connecter is video, red is right audio and white is left audio.
You can purchase converter leads (scart to phono(the red/white/yellow connecters) or many other combinations) if needed.
If you have scart connections ( a block of 21 pins) then use that if possible as it will give a better picture.
Connect the dvd out to vcr in and vcr out to the tv in.
NOTE. if you connect this way you will find that the copyright protection will make viewing dvds quite poor quality and may even be black and white or even the picture may "roll"
You may want to buy a scart block to connect more scarts to the tv then it has, also you can get these with different connections.
Samsung 2333HD to dvd/vcr combo
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
Connected samsung dvd vcr combo to samsung lcd series 6 tv via componet cables dvd works fine vcr playing but no picture help me. gordy
all i did was disconnect the component cables and connect using the rca cables and everything worked fine.
2answers
Can't connect Samsung VCR DVD combo
this will only workif the vcr has a up convert feature whit out up convert it will not work you will have to connect vcr whit yellow red and white cables then dvd and vcr will give u the picture, if u connect dvd with commponent cables if u tv has this input picture from dvd will be better
Tuning VCR into Tv
Set the LCD to TV source and tune the LCD TV channel to 3 or 4.
For best viewing experience, you should connect the LCD TV to the VCR using component / SVideo or RCA cables instead of RF coxial to avoid signal loss. Your VCR manual should indicate these types of connections.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
