SOURCE: jl audio 500-5
Assuming that you've confirmed that the speaker is in good working order and that the wiring isn't shorted in any way...
There are separate power supplies for the high and low amplifiers. It's possible that the one for the sub output has failed. If that's the case, the output transistors probably failed and that's what damaged the supply.
Generally, I'm willing to help people repair their amps but this is a large, complex amplifier and it should be repaired by a qualified technician.
SOURCE: jl; audio 500 amp
I assume the signal sensing switch you are talking about is the remote turn on for the amp. The amp should turn on when you turn your radio on, not your truck.
First try disconnecting the remote turn on that comes from your radio. After that is removed turn your radio on and them run a jumper wire from the positive voltage terminal of the amp ( the main power input) to the remote turn on terminal of the amp. If the amp turns on and you hear music, you have a problem with the remote turn on from the radio. If the amp turns on but you hear no music you have a problem with the audio input of the amp or the wiring of the speakers. if the amp does not turn on you have a problem with the amp.
I think you may have a problem with the remote turn on output of your radio. if so, you need to get the radio looked at by a service technician.
If the amp is turning on sometimes, you may just have a loose wire or faulty ground. Double check all the wiring.
SOURCE: Can i wire 3 jbl gto1204d subs into 1 jl audio 500/1 amp
You can connect them in a series/parallel configuration. Put two of them in series and then connect the last one in parallel across the two in series. This would give you an impeadance of around 2.7 ohms. Only do this if your amp is stable at 3 ohms or less. I am not familiar with the specs of your amp. If your amp is only 4 ohm stable you can not do this.
This would also give you half the power on the two subs in series as the power for the one that is parallel. The two in series would be sharing the total output signal, where-as the one in parallel would get the entire output signal from the amp.
if you were to connect a fourth sub woofer in this configuration it could give you a 4 ohm load, by adding the fourth sub in series with the single sub that is in parallel. or in other words, yu have two sets of 2 sub woofers each in series. That gives you two 8 ohm loads (two 4 ohm subs in series is 8 ohms). Then you take the two sets of subs and parallel them (two 8 ohm loads in parallel equals 4 ohms).
If i had a picture to show you it would make sense, two subs in series that are in parallel with two subs in series.
SOURCE: JL Audio 500/1 Amp
Do you get sound if you set it on full? If you don't get sound in any way it maybe broked. Do you smell burnt components? Is the protection light on? If so you probably have a shorted transistor inside. If everything looks normal but has no sound at all. The preamp circuit is probably not getting power due to a malfuctioning power supply circuit. The way a car amp works is it has a DC-DC converter, which steps up the 12 volts to two supply voltage. One is usually a -35V, an the other is +35V. To a totall of 70V. Power transistors don't operate efficiently on 12 volts thats why it is designed like that. A PWM (pulse width modulation) circuit which consist of a chip, and various components connected to it drives an array of Power FET(field effect transsitors) usually conected in parallel to add power. These FET drive two or more "powder iron core" transformer. The other side of the transformer is connected to large diodes, providing power to the transsistors that actually drive your speakers. The supply voltage to the section preamp section is usually the same as the battery voltage. This preamp section filter high frequency for things such as low pass, high pass etc, and through many stage of amplification using small transistor, the final stage is the large transistors that drive the speakers. If you can tell me more info I can help you with a step by step guide on fixing the amp.
