There is another lever at the front of the car that you need to release
too. This is to prevent the hood flying open if you accidentally pull
the release while driving. After you release the latch inside the car,
go to the front of the car, near the Audi rings, in the center of the
grill there is a small black tab that pops out when the internal hood release is pulled. Pull up on it and the
hood will open. Let us know if that works.
Under the car: You will be able to open the hood if you pull off your splash guard and use a long long flat head screwdriver or something like that. You'll see the hood latch in front of the radiator with the cable attached to it at the top near the hood, put it on the drivers side edge of the bottom of the latch and pry to the passenger side, the lever moves from the drivers side to the passengers side, the cable basically pulls the top of it to achieve this. so your doing the same thing on the bottom with the screwdriver.
Release the latch from underneath by the lever that you have to pry towards the passenger side. Then open the hood, and replace the safety release mechanism broken cable.
Yes, you will be able to open the hood if you pull off your splash guard and use a long long flat head screwdriver or something like that. You'll see the hood latch in front of the radiator with the cable attached to it at the top near the hood, put it on the drivers side edge of the bottom of the latch and pry to the passenger side, the lever moves from the drivers side to the passengers side, the cable basically pulls the top of it to achieve this. so your doing the same thing on the bottom with the screwdriver.
Release the latch from underneath by the lever that you have to pry towards the passenger side. Then open the hood, and repair or replace the safety release mechanism. This is very simple to remove out from the hood.
Try getting another person to push down above the bonnet latch as you pull the lever.They may have to push it down a few times,A sudden quick push may do it.Hope this helps
