I experienced the symptoms you did and found my Power Control Circuit Board warped when I opened up the unit. I have the 9-pin ribbon cable and replaced the Power Control Circuit Board with ereplacementparts part number BOV800XL/184A. Oven works great now.
Power Pcb Assembly Cst Type 9 Pin
Most likely suspects in this scenario would be the heating element or the temperature sensing rod. Not sure what the sensing rod setup on this oven looks like, but it is generally a few inches long, similar diameter to a charging cable for your phone, attached to the back wall of the oven and sticking out directly toward the oven door. If it goes bad, the oven may think it has reached the set temperature and turn off, but generally, it is the opposite (it allows the oven to get too hot). My guess is heating element, but the sensor generally costs a lot less to replace, though maybe not with a small toaster oven. Good luck!
