20 Most Recent Farberware T490C 1500 Watts Toaster Oven with Convection Cooking Questions & Answers
3answers
Farberware Turbo Oven -- Model 360 + Manual
The only thing you have to know is that pork and chicken cook at 325. Any baked goods with leavening in it cooks at 75 degrees less than what the recipes calls for but no lower than 275.
7/6/2020 7:30:35 AM • Farberware T490C... • Answered on Jul 06, 2020
I am looking for a drip tray and rack for my
I have this oven and I'm very much afraid the fan motor is getting ready to go out on me (I've used this oven almost 30 years). If it does go out, I'll be willing to sell the two racks and the drip pan -- if you're still looking for them then.
3/3/2019 6:23:02 PM • Farberware T490C... • Answered on Mar 03, 2019
5answers
Farberware convection broil oven modle T-4850
I have the same problem. www.repairshack.com has replacement doors but they are out of stock. You may want to check with them to see when it comes back in. Specifically http://www.repairshack.com/detail.aspx?ID=705 or call
1-888-464-0797.
8/1/2018 11:02:51 PM • Farberware T490C... • Answered on Aug 01, 2018
What type of adhesive should I use for the door on
You need a tube of permatex blue or black RTV silicone.I reglued my door about three years ago and it is still holding. Trick is to clean all parts PERFECTLY first using steel wool, a flat 4-sided file, etc.. Then clean real good with acetone (outdoors cause its explosive and toxic). After acetone dries do it again and wipe it dry with a piece of cotton jersey. Then reattach the hinge or handle sides using the silicone and tape it with blue masking tape. Let cure for 48 hours. You will have a joint as good or better than the factory joint.
1/5/2016 2:35:29 AM • Farberware T490C... • Answered on Jan 05, 2016
How do I set a farberware t490c commercial tabletop convection oven to work
Try calling or emailing Farberware (distributed by Salton/MAXIM Housewares): [email protected] OR 1-888-881-8101. Ask for Operating Manual
1/9/2015 8:43:23 PM • Farberware T490C... • Answered on Jan 09, 2015
I need a manual for
I have this manual. I have been using this oven for almost 30 years. (I love it!) However, I'm having trouble with internet connections at the moment. As soon as I can get a good connection again, I will scan the manual and upload it here for those of you who need it.
1/4/2013 6:16:53 PM • Farberware T490C... • Answered on Jan 04, 2013
2answers
Have T4800 Convection Oven. Need fan, motor and
If Farberware can't help then copy and paste this address. It will give you a list of sites that carry oven parts. Maybe one of them can help.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
5/11/2012 4:08:23 PM • Farberware T490C... • Answered on May 11, 2012
2answers
Manual for turbo-oven
4/21/2012 8:51:56 PM • Farberware T490C... • Answered on Apr 21, 2012
Need manual for Farberware convection
Farberware manuals do not seem to be available online. Try contacting Farberware Customer Service at the following site:
http://www.farberware.com/customerservice.html?hm=Y&ct=N&anw=N
For convection broil ovens try the e-mail address for Electric appliances. Send your model number with your request for a manual.
Thank you for using FixYa!
8/15/2011 8:08:53 AM • Farberware T490C... • Answered on Aug 15, 2011
I have a faberware convention
Here is the contact info for Farberware: Electric Appliances
[email protected] 1-800-233-9054
If that doesn't help then try this address that gives you a list of websites that sell oven parts.
4/9/2011 6:33:09 PM • Farberware T490C... • Answered on Apr 09, 2011
Have T4800 Convection Oven, need
Not knowing where all you have checked, here is contact info for customer service for electrical appliances from Farberware: Electric Appliances
If that doesn't work, then here is an address that will give you a list of sites that carry oven parts:
2/20/2011 7:28:15 PM • Farberware T490C... • Answered on Feb 20, 2011
I have a farberware convention turbo-oven model
The top temperature is actually 475 (which is 550 in a regular oven). That's with the dial turned as far as it goes to the left. Don't know how you'll figure out the settings for the temperatures above 350, unless you measure the intervals below 350 and mark them off on the other side some way.
Here's a picture of the dial on my oven:
1/23/2011 6:28:10 PM • Farberware T490C... • Answered on Jan 23, 2011
What are the dimensions - I can't find the answer
20" Wide X 14.75" High X 13" Deep (plus 2" door handle)
1/8/2011 2:56:46 AM • Farberware T490C... • Answered on Jan 08, 2011
Farberware Convection Oven T490c does not turn on.
It is usually one of two items that could cause this problem. You need to take the outer shell off. Lots of screws. Pull the "brain board" from the right, front of the oven. There is a relay housing. This 30 amp. relay is made by Omron. Look at the connector pins on the back side of the relay, especially the white wire that goes to the distribution block then on to the heating coil. I find that the soldered pins on the pc board next to the relay often get so hot that they 'shed' the solder. If so, simply clean well and re-solder. The relay itself can also go bad. Unfortunately, I haven't been able to obtain replacements. What I did on one oven was to buy a 30 amp, open frame relay (~$20). Mount it on the chassis near the fan. Remove the Omron relay and simply run the appropriate wires to the open frame relay. That works very well.
11/5/2010 6:57:25 AM • Farberware T490C... • Answered on Nov 05, 2010
Where can i find a snap type thermal fuse T350
goto
www.partstore.com
they will have most of your parts available
do a part search as well as a model search
they have most of the parts available for faberware
11/3/2009 9:11:12 PM • Farberware T490C... • Answered on Nov 03, 2009
Turbo oven model T-4850
I have two tubo ovens. Would anyone know if they are all supposed to "ding" or "ring" when the timer goes off. My one does. Bought both used at a thrift store diff times
5/20/2009 6:05:09 PM • Farberware T490C... • Answered on May 20, 2009
Model 460/5 can not control the heat
I would have to say that your issue is thermostat related.  The thermostat only send a signal when temperature is reached, not what the current temperature is.  So if it is malfuntioning, the desired temperature will never be reached.  Therefore, not sending a signal to cut the heat, even though it is 350.
3/4/2009 3:17:00 AM • Farberware T490C... • Answered on Mar 04, 2009
Farberware T490C 1500 Watts Toaster Oven with Convection Cooking Logo
48 questions posted
Top Farberware Toaster Ovens Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Farberware Toaster Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Farberware Toaster Ovens
Most Popular Question
t4800 convection oven need
  • Toaster Ovens
