Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
A
Anonymous Posted on Jul 14, 2014
Where do you spray carburetor cleaner in 675 series Briggs & stratton engine
tebrown507
Level 2:
Sergeant:
  • Expert 415 Answers
  • Posted on Jul 15, 2014
tebrown507
Expert
Level 2:
Sergeant:
Answers
415
Questions
0
Helped
110994
Points
506
Remove the air cleaner cover and the air filter then spray into the filter box.
5 Related Answers
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Apr 13, 2011
SOURCE: where is the carburetor on
The carburetor would be located BEHIND the air filter housing and air inlet tube. The air filter housing should have a removable (by screw or clip) cover.
Anonymous
  • 126 Answers
  • Posted on Apr 14, 2011
SOURCE: I have a Briggs &
Yes, u can drain it without warming it up,But i would drian the oil refill it with new oil run it for a minute shut it off drain the oil again so u will get any residue out of the eng......
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Apr 27, 2011
SOURCE: my briggs and stratton 675 lawn mower won't
I am guessing that this is your ENGINE model number: 126K02-0512-B1
Using this reference:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=126K02-0512-B1&dn=35820003
Check to make sure that the choke item number 97 is not sticking.
Then remove the float bowl nut and float bowl assy. Clean the fuel passages in the base of the carb with carb cleaner including the area where the bowl nut screws into. There is a fixed jet orifice that must be cleaned in the threaded area. Also clean the visible brass tubes in the top of the carb.
Check fuel flow with the bowl removed. You should have a good fuel flow with the float angled down and as you lift it level fuel flow should STOP. If you do not have fuel flow... remove the float pin, drop the float and needle and celan out the hole where the float needle was. Remove the main fuel line and check for fuel flow. Use carb cleaner in the hole where the fuel line connects. If you do not have feul flow from the fuel tank.. check the tank port and look for any kind of in line filter. If you find a filter... check the line before and after the filter for fuel flow. Once you have established fuel flow Reassemble carb
Check the spark.... if you have no spark
First check the thermostat by just disconnecting it. Item 291
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=126K02-0512-B1&dn=35820004
Then retest your spark. If you have spark with the thermostat disconnected the themostat is bad. (Most engines use a low oil level sensor..... this one uses the thermostat)
There is an electrical contact on the throttle plate that is grounded when the throttle is selected to off. Make sure the throttle plate lever moves off of the contact when you advance the throttle. ALSO... there is another ground / contact on the engine brake. Make sure that when the engine brake is released that the brake lever moves away from the ignition grounding contact.
The above are the basics.... If after doing ALL of the above you still have problems with ignition then suspect the ignition components.
Thanks for choosing FixYa,
Kelly
#1 Taper
Jim Parker
  • 1041 Answers
  • Posted on Aug 13, 2011
SOURCE: Craftsman 675 Torque 190cc 21"
If your carburetor has sat for a few months with fuel in it, the fuel may have gone bad. Fuel turns to turpentine after a while and leaves light yellow deposits behind. These deposits will keep your carb. from working properly.You need to dip the carb. in carburetor dip for a few hours to get rid of the deposits. You can also take the carb. to your local parts store where they may do it for free.
You may also have to replace the gasket and needle valve too if it has been sitting. So basically, you need to do a carburetor rebuild.
If the float sounds like it has liquid in it, you will need to replace it too.
Good Luck!
Jim
Anonymous
  • 6468 Answers
  • Posted on May 12, 2012
SOURCE: Lawn mower 675 series 190 cc Briggs Stratton 22
did this happen after hitting a rock?and you sheeredthe flywheel key is the gas older than 30 days?drain and refill if still no good clean the carb
1helpful
I see no vent holes om my 675 series briggs and stratton engine fuel cap
there are holes in it should be three or four. a rubber diaphram is covering it but they are there
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 • Garden
It is leaking gas on the side
Check your fuel lines first ! ! Slight crack might be the problem. If it has sat for a long time, the needle valve may be stuck open, causing the fuel to spill out of the carburetor . You would need to remove the fuel bowl and spray a little carb cleaner in there to loosen the needle valve.... Good Luck
2helpful
Where is the carburetor on the Craftsman 675 Series 190cc 22" cut self-propelled lawn mower?
Gasoline leaking into air filter on Briggs & Stratton engine
The float/needle-valve/seat need to be looked at in the carburetor base. The float is not shutting off fuel flow when bowl is at design fuel level. Look for dirt/varnish or anything that interferes with float free movement or preventing the needle valve to close with the seat--usually, just cleaning these parts with spray carburetor cleaner and wiping with a clean cloth will restore operation. Try not to bend anything on the float assembly. Hope this helps!
B & S 675 series engine timing question
The gear on the crankshaft is 'keyed' and has a dimple on one of the teeth. That dimple aligns with the dimple made into one of the teeth on the camshaft.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
