Tumi Dakota 56913 Berenger Steel Watch for Men Logo
A
Anonymous Posted on Jul 14, 2014
What is the battery model for dakota 75769? - Tumi Dakota 56913 Berenger Steel Watch for Men
1helpful
How to set the time on a Dakota one button watch
To set the time on a Dakota one button watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you can try the following steps:
  1. Press and hold the button on the top right side of the watch: Press and hold the button until the time display appears.
  2. Set the time: Use the button to set the time. The specific sequence for setting the time will depend on the make and model of your watch.
  3. Exit the time setting mode: Once the time is set, you will need to exit the time setting mode. The specific steps for exiting the time setting mode will depend on the make and model of your watch.
It is important to note that the steps for setting the time on a Dakota one button watch may vary depending on the specific make and model of the watch. If you are unable to set the time using the steps above, it is recommended to refer to the user manual or contact Dakota customer support for assistance.
If you have a "his and hers" set of Dakota watches, the steps for setting the time on both watches should be the same. You can use the steps above to set the time on both watches.
2answers
Altimeter Compass. Where can I get setting instructions?
Try contacting Dakota directly to request them.
My atomic watch wll not let me to select the proper city code (NYC) or make any other selection to reset the time. It was great for four months after Christmas (a gift) but the battery ran out in April. ...
My best advice to you is to contact Dakota or send to Dakota. It may not be what you want to hear, but its probably going to be your best interest to send back to them so they can properly care for your watch.
http://www.buydakotawatches.com/faq.aspx
Good luck.
4helpful
2answers
Hello i changed the battery on my dakota angler II and the only thing that works is the red light, no time analog and or digita, none of the buttons do anything except the red one for the light.
Did you change the battery yourself? Did you have instructions? The reason I ask is only because some watches/etc have more the one battery for various functions. Sometimes there are more batteries underneatch the battery you replaced.
I would call the manufacturer and ask them if you have the number.
WATCH STOPPED RUNNING
You need to open the watch to see the model number on the battery. If the watch is water resistant, which I believe this model is, then you will also have to replace the rear seal and pressure test the watch to insure that it remains water resistant and your warranty in tact. I would see a watch specialist who can pressure test on site. There are a few national chains that I can think of off the top of my head.....Precision Time and Dakota Watch.
1helpful
Watch battery number for dakota watch
This watch requires a size 1620 battery, available at all Dakota Watch Company store locations, and most electronics stores. Dakota Watch Company always recommends taking your watch to one of our store locations or a reputable jeweler to reduce the risk of damaging your watch during a battery change.
We are sorry to read of your trouble with receiving technical support. We will be happy to answer any questions regarding your Dakota watch. Please feel free to contact our Customer Service by email at [email protected], or by phone at 1-888-459-0404. Thank you!
Lose or gain time?
We are sorry to read of the trouble you have experienced with your Dakota watch. The problem you have described is typically a mechanical issue that requires a movement overhaul completed by our repair department. Depending on the details of your purchase (date, place of purchase, receipt, etc) this service may be covered under warranty. To determine how to submit your watch for repair, please visit your nearest Dakota Watch Company store location, or contact our Customer Service by email at [email protected], or by phone at 1-888-459-0404. Thank you!
Top Tumi Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Tumi Watch Expert? Answer questions, earn points and help others
