The error is not appearing on my end. Please check the troubleshooting section of your manual for the error 19. And if necessary, you can call Runco directly to help overcome the error. This is their phone number: 1-888-785-2677. Thank you.
That error means that the lower oven is not heating fast enough. IT should rise to over 150 in 5 minutes. Check the broiler and the baking coils for continuity. If they are ok then check the radiant heater in the convection fan housing.
It means your driver to your DVD/CD is missing you will need to download a driver or reload to fix this problem......try ..................http://www.driverfinderpro.com/lp/error/s-fix-device-code-39-errors.php hope this helps
ERROR-19 Communication failure Perform one of thefollowing operations- -Turn the ignition switch OFF and back ON. -Disconnect the USB portable audio player/USB -Change to a different source. Then, return to the USB portable audio player/USB memory.
The only error code 19 for the ITC222 chassis listed from RCA/Thomson for 19 is invalid chassis detected. Which doesnt make sense unless you have replaced a PCB with a wrong part number.
