Carrier 38CKC036 Air Conditioner Logo
A
Anonymous Posted on Jul 10, 2014
Part number for dual run capacitor of Carrier 38ckc036350
Jake Sysk
Level 3:
Master:
  • Master 602 Answers
  • Posted on Aug 12, 2014
Jake Sysk
Master
Level 3:
Master:
Answers
602
Questions
0
Helped
173711
Points
1508
Capacitors are rated uf and voltage (35uf 5uf 370 volt) should be right for your unit but the size will be on the old capacitor.
5 Related Answers
Anonymous
  • 410 Answers
  • Posted on Mar 13, 2009
SOURCE: Age and tonage of carrier 38CKC036350 S/N 2005E40526
its a 3 ton unit manufactured in 2005
the 36 in the model number indicates tonnage 12,000 btu's to a ton times 3 equals 36
the 2005 in the serial indicates year made not sure what month but if i had to guess i'd say May of '05
Thanks Peyton
Anonymous
  • 340 Answers
  • Posted on Jun 28, 2009
SOURCE: I have a Carrier 38ckc036350 Air conditioner. The
Have you checked your circuit breaker? Capacitors are located in side the unit in the control box. TURN OFF THE POWER. you need a capacitor checker i assume you have one if not have a qualified service person check it out you'll be money ahead in most cases. good luck Tom
pillarair
pillarair
  • 17 Answers
  • Posted on Jul 21, 2009
SOURCE: size and year of Carrier
3 ton air made in 2003
Anonymous
  • 43501 Answers
  • Posted on Sep 28, 2010
SOURCE: carrier 38CKC036350 condensor fan not spinning
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Anonymous
  • 12 Answers
  • Posted on May 22, 2011
SOURCE: carrier model 38txa024300 ,condesor fan
If the fan spin freely then the capacitor could be bad. Otherwise, if it spin with difficulty then it need to be cleaned and lubbed.
Where do I locate compacitor on carrier 38txa042300 for exterior unit
If you're not familiar with working with electricity, or run capacitors, please do not attempt. If you internet search, dual run capacitor, and search by image, you'll learn what a run capacitor normally looks like(if you're not sure). Most all condensers have an electrical "panel", where most all electrical components are installed. Please be advised, run capacitors are know for electrocution! Call a professional if you are not certain.
1helpful
How many tonnes does this air conditioner have?
First digit after 38CKC_0_ is the seer rating this is a 10 Seer unit.the next two digits are BTU's of cooling to the thousands. For every 12,000 BTU's you have 1 ton of air conditioning.38CKCO_36_ would be a 3 ton unit.
Serial number first two digits are the week the second two are the year24 would be 24th week. 02 would be 2002
1helpful
My condensor fan and compressor on my Carrier AC (Model# 38ckc036350) stopped working, so I replaced my capacitor and they both work fine now. The problem is my house won't cool down. There is c
Often after a repair has been made, the air conditioner will take hours to readjust back to normal. When the system has been off for to long, not only does the heat in the house rise, but so does the humidity, which has to be pulled out of the air first before it really starts dropping in temp. You could have a low charge on refrigerant, dirty filters, etc. More than once I have ran into things that were just coincidence after a repair that showed up. Since you just replaced the capacitor, I would make sure the fan motor is turning in the right direction and there is nice air flow coming out of the condenser, some times if one wire is wrong, it can cause it to spin backwards, which will work, but just barely. The air needs to be pulled through the coils, not pushed. Hope this helps!
2answers
Carrier 38CKC036350 condensor fan not spinning makes humming noise compressor hot fan can be turned by hand
heatman101
1helpful
My carrier 38ckc036350 is 6 years old. Today the compressor stopped working. The fan outside comes on and every few min i hear an electrical buzz like the compressor is trying to be energized. Are there...
Hi!
It sounds like the capacitor and/or compressor are quitting. Try getting a Start Capacitor of the same uF (I think 35 uF for Commpressor and 5 uF for fan motor) as the one you have, OR get a Start Kit from any AC parts shop for about $10 and hook it up in line with the old capacitor, if you have a two terminal capacitor plug the terminals one, on each end, if you have a 3 terminal called DUAL Capacitor, each terminal is stamped with the words FAN, HERM and the letter C for common, one lead goes in the C terminal and the other one goes on the HERM.
Install it and turn unit ON. Good Luck!! Don't forget to rate this post!!
P291-3554RS dual cap is the Carrier part that is called for.
Are you talking about a start capacitor or a run capacitor?
Usually a dual capacitor is a metal can type capacitor with 3 terminals.
C - which is run for compressor and fan.
Herm - is start for the compressor.
Fan - is start for fan.
A start capacitor is a black plastic capacitor
It is in series in the run wire to the potential relay, one side goes to run on the run capacitor and the other side goes to #1 on start or potential relay.
1helpful
4helpful
I have a Carrier 38ckc036350 Air conditioner. The inside blower turns on but the outside unit only makes a buzzing noise. I belive it is the capacitor, but I don't know where it is located any ideas?
1helpful
Thanks Peyton
Top Carrier Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
