SOURCE: replace handle bars
Mine had wiring inside the bars as well. Basically I removed the controls from the bars, and removed the 2 bolts holding the handle bars on. I removed the RIGHT side gas tank after draining it. I intended on cutting the wires to the connectors, pulling the wires out of the old handle bars, and pulling them back through the new bars. Note: Mark the black wires very carefully, since there were 5 black wires in the two connectors and they are all unique wires. The colored wires were easy, just match them back up. Several tricks I found on line. Use a string and a bolt to fish a pull line down through the new bars then pull the wire bundle through. This worked great on both left and right wire bundles. I then bolted the new handle bars in place and remounted the controls. I then replaced the shrink tubing up the bundles that hid the actual wires as they came out of the handle bars down to where I cut the connector wires, behind the right side tank. Next I stripped and tinned all the wires I cut (twist and get a little solder to stick on the wires) and stuck little pieces of shrink tubing up or down the wire so after I resoldered the wire I could shrink the insulation back over the splice. I picked up the shrink tubing and some extra wire a home depot. I had a soldering iron, and heat gun so away I went connecting the dots again. Litte tedious but hey. It saved me somewhere between $500 -$700 bucks which is what the harley shop quoted before I started. I tested each function, then reinstalled the gas tank and tightened up all the stuff. Below is the pin out in case you do loose a wire marker, like I did. Good Luck.
SOURCE: will a gas tank off a 5 harley dyna wide glide
It sure will!! You answered your own question. guess i get no points for this one.
SOURCE: speedometer cable 1998 Harley Road Glide
There is a little set screw that stops it from coming out. remove the set screw then I believe you have to unscrew it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_5bac37c3cb991fdb
SOURCE: 2001 Road Glide Harley
Your bike has a stator and a voltage regulator. On the right front down tube you will find the plug for the stator and the voltage regulator, unplug the stator from the voltage regulator and use a meter to read the out put from the stator. I don't know the value's off hand but as you rev the motor the voltage should climb. If it doesn't your stator is bad, major job. If it does measure the voltage on the battery cables, when you rev the motor they should climb to a little over 14V's.
