Rheem Paloma PTG-74PVP /  RTG-74PVP Liquid Propane Indoor Logo
A
Anonymous Posted on Jul 09, 2014
Do you have instructions for flushing or descaling the Paloma PTG-74PVN water heater?
I need to descale my home installed Paloma water heater for the first time.
Suzette Arch
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 24, 2015
Suzette Arch
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
471
Points
6
At this time I am not getting any error codes.
Thank you,
Suzette
  • Gene Haynes Feb 24, 2015
    Call Rheem and get name of local technician... or check resources on following link:http://waterheatertimer.org/Troubleshoot...
Gene Haynes
Level 3:
  • Rheem Master 5,391 Answers
  • Posted on Aug 17, 2014
Gene Haynes
Rheem Master
Level 3:
Answers
5391
Questions
0
Helped
2606639
Points
14124
3 Related Answers
Anonymous
  • 332 Answers
  • Posted on May 29, 2009
SOURCE: Paloma PTG 74PVN Tankless Water Heater
did you check the filters on the the water valves, i am not exactly sure about your codes that are shoeing but if you could read it and post them, i know on some of the units 76 means there is low water pressure and the filters are behind 2 caps one on each side above the shut off valve take off the caps and remove the screens, clean them and replace them ,, make sure you turn off the water on both side first or you will get wet
Anonymous
  • 244 Answers
  • Posted on Dec 06, 2009
SOURCE: PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Lickzee
  • 68 Answers
  • Posted on Aug 12, 2010
SOURCE: Indoor Paloma water heater showing error message
that is the water inlet temperature sensor fault.. check and clean scale from sensor or have it replace by a qualified technician
Paloma tankless water heater model no PTG-74XP-2 error code c8
In several cases i have had to change the pcb board.... code 76 is no communication between remote thermostat and pcb..... this is a problem the first generation rheems seem to be having.... contact rheem if under warranty you will need to get pcb and program chip sent to you. Really need a experienced tech to install board and program it for you...... hope this helps...
1helpful
Hi. We have a Paloma Tankless Water Heater model no. PTG-74PVN-1 and we keep getting the error C 7-76 or C 8-76. We cleaned the filter but the problem is not going away. The hot water turns off after a...
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
1helpful
Thermostat flashes IL ? Model PTG-53PVN
http://www.palomatankless.com/owners/homeowner+trouble.lasso#28-11
The Controller displays error code "1L."
There is a build-up of lime in your Paloma.
Contact your plumber to service the Paloma by flushing out the lime.
Also search u-tube for flushing lime out of tankless.
3helpful
Water heater starts, then shuts down, then starts again, shuts down, etc.
have you tried cleaning out the inline water filter?
sometimes a good flushing will also do the trick. might have some scale buildup inside.
do you have the instruction manual? this will tell you exactly how to do it. if not, I might have one I can copy and send you.
Indoor Paloma water heater showing error message C2 31 - there is no hot water. Any idea? Model #: PTG-74PVN
2helpful
2answers
HTH,
Mike...
I have a paloma ptg-74pvn and the digital temp. display keeps shu
How reliable is your AC? With the digital r/c connected, every time the heater recovers from power outage it's in the OFF default state. If you can not fix the power issue, disconnect the remote control. The w/h will recover in the ON state.
8helpful
5answers
I have a paloma tankless water heater about 3 years old model PTG-74PVN and it works for 2 minutes and shuts off with error code C4 and 13 flashing. (City water pressure is fine)Can anyone help? Thanks...
I had the same problem with my Paloma a year and a half after installation...contacted Rheem customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
