Olympus Stylus Tough 6010 / ? TOUGH-6010 Digital Camera Logo
A
Anonymous Posted on Jul 08, 2014
How to connect camera to laptop? - Olympus Stylus Tough 6010 / ? TOUGH-6010 Digital Camera
1helpful
I have a BENQ DC E800 camera and i've installed the driver in my BENQ Laptop but every time i hook my digital camera to my laptop it says unknown format and cannot be recognized and on my camera screen...
When you installed the driver do you have connect the camera to laptop, if the laptop cant't find the camera be connect to laptop when you installed the driver it will failed. Else, as to save life of your camera, suggest that to use card reader instead of connect camera to laptop.
I am using SONY DSC T 300 digital camera. I am able to take photo from camera. But Once I have connected my camera in to my laptop am not able to see the folder & picture through my laptop.
The camera is not connecting to the laptop as there are some errors. If there is any drivers installed please remove them and then reinstall the drivers from Sony support.
Then connect the camera as it will be detected and installed as a new hardware.
the folders will now open for view.
What does usb device not recognized ?
The best you can do is,
Turn off the PC/Laptop
Disconnect the USB cable from Camera to pc/laptop
Disconnect the power cord connecting the pc/laptop and the wall jack or surge protector
Disconnect the power cord connecting the camera to wall jack or surge protector
wait for 5-10 mins
Connect the power cord of PC/laptop and turn on the pc/laptop and login to your PC
Connect the power cord of Camera to wall jack or surge protector
Connect the usb cable or camera to PC/laptop
It should get recognised and work fine.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Olympus Stylus 770 SW is not seen when connected to a PC or laptop. The camera is off when connected to the PC/Laptop and powered on once the connection is made. Note: This camera has been connected to the...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
I want to know one thing.
You didn't specify a make or model laptop. Some have cameras built in, some don't. You will need to research the laptop that you are considering to tell if the camera is standard, optional, or not available. And yes, peripheral (external/add-on) cameras are available.
1helpful
My laptop turns off after connecting camera, i have an asus laptop, and after connecting the cord from camera to laptop the laptop shuts down and i have to disconnect and then reconnect everything to...
your laptop has to work harder when when things are connected to it thus getting hotter. it's more than likely going into thermal shutdown because the fan is dirty and blocking the cooling exhaust hence no cold air circulation.
have this cleaned and the surrounding area and all should be well.
Laptop does not see camera. A different laptop
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Camera not connecting to computer
You'll need to update the camera software for use with Vista. The Vaio isn't the problem. Thee updates for the F20 can be found here: FujiUSA
2answers
Install the camera to mine laptop
Enter Canon web site and look for your camera drivers to be used with the VISTA OS (I hope they already have it. Download the drivers to your laptop. Good Luck !
1helpful
Difficulty connecting to laptop
Assuming your laptop is XP then it should recognise the camera as another drive. Have you installed the Camera software that come on a disk? If so uninstall it and let Windows do the work. The other way is to invest in a cheap USB card reader
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
