Volfenhag ZX-8290 - 2-Channel 1200 Watt Bridgeable Power Amplifier Logo
A
Anonymous Posted on Jul 07, 2014
Whats the amp load on a zx-8290 - Volfenhag ZX-8290 - 2-Channel 1200 Watt Bridgeable Power Amplifier
Matthew Spark
Level 3:
Genius:
  • Master 1,066 Answers
  • Posted on Jan 03, 2015
Matthew Spark
Master
Level 3:
Genius:
Answers
1066
Questions
Helped
298187
Points
2431
  • 2 Channel Bridgeable 1200W Power Amplifier (4 ohms)
  • 2 Ohm Stable Stereo
ZX 8290 Volfenhag 2 Channel 1200 Watt Bridgeable Power Amplifier
Hi ...where can I get parts for pmp3000
Try these suppliers-
Behringer Full Compass
Legacy Service Parts List
MUSIC Group
You can also call-
Phone - 702-800-8290 (US & Canada)
Email - [email protected]
May 24, 2016 • Music
Armitron all sport 40/8290
please give manual of armitron watch wr 330ft of model 40/8290
What size wire should i have for two 12 volfenhag subs
I would use 10 to 12 gauge wiring. As fare as your amp's fuse...Check to make sure you are using the correct amp fuse. Make sure your subs are wired to a ohm load your amp is stable with. Check your ground and positive connections. Check and make sure your amp's gain settings are correctly set. Your amp's gain should not be turned all the way up.
I have a volfenhag zx-8290 amp but i need to know wat size fuses it need
In all the pictures I can find, the fuses are clear, which means they are 25 amp fuses.
Jul 03, 2011 • GPS
Need help setting amp right
volfenhag's are cheap. you get what you pay for. that is the german equiv. to pyramid or kraco.
2helpful
2002 ZX-9R: what are the torque settings for front and back wh...
Hi
Both front & rear axle nuts should be torqued to 125Nm (newton/metres) & the front wheel clamp bolt should be 20Nm
Ride safe
Bike-Doc
Please mark this as very helpful (if it has been!!)
Zx-8400 amp too much for zx-4812?
The amp and sub combo should work fine the subs can really take a crapload of power-i have a neighbor thats running 1200 watts rms to each sub in his caddy and OMG- its sick. Your amp should be pushing around 800 watts rms(continous) to the sub which should do very well-my concern with your setup is that the sub is designed for a vented box- you can use any box u want but im just suggesting that you use a good solid vented box with these subs- my other concern with your setup is that having only the single sub if its a dual coil 4ohm + 4ohm coils then you might run into trouble if you dont have it set up right-by that meaning to get all the power handling capability of the sub you would want to use both of the coils right? well to do that you have to either wire the coils in series or wire the coils in parallel right? In series the coils will yield an 8 ohm load to the amp and youll only get about 400 watts from the amp bridged into that 8 ohm load- on the other side of that if you wire the coils in parallel then the cols yield a 2 ohm load and that could cause the amplifier to become unstable and fry its little guts. All of this is assuming that the amp is made to run bridged at 4 ohms- if it is 2 ohm stable in bridged mode than you have nothing to worry about. Now the popping noise- that sounds like its coming from the amp somehow and just feeding through to the sub-like you ive never heard a sub popping unless its bottoming out and you say its not so its gotta be the amp id say-if it were me id check all power connections especially the ground for the amp . It could be that on the heavy bass notes that your amp is not getting enough juice -throw a 3.5 farad capacitor on the power line and see if that helps your system out-
1helpful
Yes i was wondering what would be the best way to wire my system. i have to kicker L5 4 ohm 10in subs and one kicker 1000 watt mano amp. what wolud be the way to get the best bass out as possible.
Hello eaglepower_2,
Well, to get the maximum power from the amp, you really need a 2ω load. Unfortunately, you cannot get that from 2 L5's with 4ω voice coils. You can get either 1ω which will burn your amp up, or you can get 4ω, and your amp will put about 500 watts RMS into that load.
To get the most from your amp, you really needed the L5's with 2ω voice coils. That way, you could run the voice coils in series and the subs in parallel, resulting in a 2ω load, exactly what your amp likes. If you can exchange them for the 2ω model, I would.
Here's the link to Kicker's manual for the ZX-1000.
http://www.kicker.com/sites/default/files/2008%20ZX%201000%201500%202500-1%20e01%20web.pdf
Hope this helps.
2answers
Top Volfenhag Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
