To close the question:
Hold the dispenser with your thumb in the groove. ...
Next, position the nose of the dispenser flat and at an angle on the area to be corrected.
Press down firmly and gently move dispenser from left to right across the correction area.
It is best to use an electrical fish tape while doing electrical work.
SOURCE: margins will not hold, have to keep resetting them.
Auto margins are permanently stored in the Swintec 8014S. If you set new margins within those margins, they should hold. If you set them outside of the auto margins you will have to use the MAR REL key to release the auto margins, and then set the new margins. All margins are set by pressing the Left or Right Margin Set keys.
These settings are stored in a memory circuit that is powered by a battery that is automatically charged when the typewriter power is on. If you still have trouble with the margins releasing after you turn off the machine, you can try one of the following:
(1) Keep your typewriter on for a couple of hours so the battery can recharge and then save your margin settings
(2) Replace the battery which may have died after all these years. You would need to bring your Swintec to a local dealer for the part and replacement service.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
SOURCE: How do I type degrees symbol on a Swintec 8014 S?
Tou have to go into KBII mode CODE and 4 or 5 KBII is marked above it then you can get to the Extra char. on the keys.
DickyO
SOURCE: how do I install the
Move the red lever to the front, lift out old ribbon, put in new ribbon putting it thru the 2 lifter arms, move the lever back.
DickyO
SOURCE: I have a Swintec 8014.S. How can I get a manual
go to Swintec.com. They still sell those manuals.
SOURCE: need free downloadable manual for swintec 8014 s typewriter
reset daisey wheel on tandy word processor
