20 Most Recent
Swintec 7040 Typewriter Questions & Answers
Beeping when turned on
the rod down inside the machine needs lubriacation. take some light machine oil and lude the rod move the carrage back and forth now clead the rod with a cloth then re oil the rod and you should be good to go. try this and see if it fixes the problem
Why it is not typing correct letters
Check the Pitch selector slide switch on the L. side of the keyboard it should be in 10 or 12 not in PS, slide it up and down a few times they do get dirty.
DickyO
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at
Swintec Typewriter Supplies .
WWW.BROTHER.COM
If this is a swintec go to NADIST.COM click on current models. The Nakajima AE 714 is the same typewriter.
DickyO
How can I set a right hand tab
I assume you are talking about Flush Right Tabulation.
To set a flush right tab:
(1) Position the carrier (or cursor) at the point where you want a flush right tab to be set.
(2) Hold down the
Tab set/clear key and press the
2 key.
To clear a flush right tab:
(1) Press the
Tab/back tab key to move the carrier (or cursor) to the flush right tab position.
(2) Hold down the
Code key and press the
Tab set/clear key.
To use a flush right tab:
(1) Press the
(2) Type the text. Characters will appear on the display as they are typed. Corrections can be made on the display before the text is printed.
(3) Press the
Print key. The text is printed aligned with the flush right tab position.
To find out more about your Swintec 7040 typewriter, you can buy a PDF manual for only $10 at:
Swintec Typewriter PDF Operations Manuals 10 emailed
How do I get the big base wheel back in
If you are talking about the platen knob if it won't snap into place the plastic is probably broken. We sell them for 15.00 includes shipping.
DickyO
216-269-3918
