I have a st george double wall oven. when using the higher temperatures, say 220c and upwards the oven will suddenly shut down. I lose all digital displays and oven cannot be turned back on until it has cooled down sufficiently. usually about 20 minutes. digital panel will not display until this happens and oven appears to reset itself with time reverting to 0.00. the oven is about 12 years old and has only begun to do this in the past 12 months and only at the higher temps.
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
