Here are some troubleshooting steps you can try to pair your woofer with your Vizio VHT215 soundbar:
- Power cycle: Turn off both the soundbar and the woofer and unplug them from their power source. Wait for a few minutes before plugging them back in and turning them on again.
- Reset the soundbar: Press and hold the Bluetooth button on the soundbar until you see the light on the front panel start to flash rapidly. This will reset the soundbar and put it into pairing mode.
- Reset the woofer: Press and hold the Pair button on the back of the woofer until you see the light on the front panel start to flash rapidly. This will reset the woofer and put it into pairing mode.
- Check the distance: Make sure the woofer is within the recommended distance from the soundbar. Typically, this is around 30 feet or less.
- Check for interference: Other wireless devices or electronic equipment in the vicinity can interfere with the Bluetooth signal. Move any such devices away from the soundbar and woofer, or turn them off temporarily.
- Replace batteries: If your woofer uses batteries, make sure they are fresh and installed correctly.
If none of the above steps work, you may need to contact Vizio customer support for further assistance.
