Pull lines from tank making sure where each goes to carb. Rinse tank out with carb. Cleaner then blow out with compressed air. Cut hoses to proper length as old ones but allow 1 extra inch. With this inch cut with scissors making a tapered end, drop oil on holes in tank to lube as you thread line into holes twist and turn hose into tank until you can get to ends of hose with needle nose pliers and then pull hose until you can cut of taper and install fuel filter in correct hose.
SOURCE: oil/gas ratio for a modle UTO8110 homelite leaf blower
you can run 32:1 if you want to it wont hurt it but it may foul a plug since its more oil, 50:1 is the best ratio for your blower
SOURCE: homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
SOURCE: How to you repalce a fuel line on a weedeater gb1/22v leaf blower
When replacing fuel line, make sure that you have the correct size lines. Depending on the size of your engine, the lines may vary in size. The primer bulb line will sometimes be larger in diameter than the fuel line to the carburetor. The primer bulb line will be the shorter of the two. When replacing the fuel line, make sure you have enough line to go from the bottom of the tank up to the carburetor. Give yourself a couple extra inches to work with. Cut one end at an angle, this makes it easier to feed down through the hole. Continue feeding the line until it comes out of the gas cap hole. Then cut the end of the line square again and attach the fuel filter that goes on the end of the line. Place the filter back in the tank, then adjust the line so that the fuel filter lays comfortably at the bottom of the tank. Then attach the other end of the line, (where you inserted it), to the carburetor, cutting off any extra line you may have.
SOURCE: How do I replace the fuel filter and the two fuel
Take your Model number of your machine and the model, type, and code of your motor to your local small engine repair shop and have them get you your replacement filter and also pick up new gas line. When you replace your fuel lines do one at a time. All you have to do is pull a fuel line off, cut new line to length and re install. As to the filter in the tank, I usually take a coat hanger and fish it up to the top and then use needle nose pliers to grip it. Then just pull off the old filter and install new one.
good luck
Testimonial: "Thanks for your help with the solution on replacing the fuel filter on my Homelite leaf blower. You guys are "ACES"! KB2MKP"
SOURCE: My Homelite backpack leaf blower runs until tank is 1/2 full
I believe you to be correct in your diagnosis.
1) remove the fuel tank
*this will give you an idea of how lines are routed and fitted into tank
2) install a new hose through to tank fitting and make sure to retrieve the old hose & filter inside the tank, so that you can attach the filter to the new hose. The filter is weighted so that it falls to the lowest point to pick up fuel.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
