Would you be able to show me where each wire is connected on the motor for a Electrolux Epic 6500 Thanks [email protected]
SOURCE: Repair manual for Electrolux EPIC 6500 SR
I don't have a manual for these but the trickiest thing about these units is taking them apart. If you have an Aerus/Electrolux dealer near you, it's not a bad investment to have them install the motor for you. You would probably receive a warranty with the work, and the things a long time. Great return on investment. But if you are determined to do it yourself, open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. Good Luck!!
SOURCE: Replace power switch - Electrolux Epic series 6500
well, i post an answer in the wrong field, and i can't find it, so i will type one more time.
slide two vinyl side pieces off, and remove top halves. remove two screws from the switch, and remove it from top halve. between switch and outside button is a plastic rocker, which is broken. you will find two broken pieces, one spring for the rocker piece, and one small plastic rod, which goes inside of the spring for support. i do not know if part is available, but you can for quick fix like me, turn the switch on by the hand, assemble unit, and plug in, and plug out from the wall. whay? i dont have electrolux store close by.
john
SOURCE: i have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
