Yes, the Panasonic KX-T7667 phone and the Panasonic KX-TES824 PBX are compatible.
The KX-TES824 should be able to accommodate different handsets because it is made to work with a variety of Panasonic phones, including the KX-T7667 model.
You must connect the KX-T7667 phone to an available extension port on the PBX and configure it with the proper parameters using the PBX programming software or a web interface in order to add the phone to your current PBX system.
It's vital to keep in mind that the KX-T7667 is a proprietary phone made just for Panasonic PBX systems and might not work with other phone systems or third-party hardware.
The base of your phone system is the KX-TG4131. The handset/base combination packs have a slightly different model number (KX-TG4132 for example). Assuming that you want to change the greeting of the answering system, you need to press Menu # 3 0 2 (when the phone system is in standby mode) from a handset. (Alternatively, press Menu and use the arrow keys to navigate to Answering Device. Press Select and navigate to Greeting. Press Select again and navigate to Record Greeting. Press Select and navigate to Yes. Press Select one more time. When you hear the beep, hold the handset about 8" (20 cm) away from you and speak your new message clearly. Press Stop when finished. The recording will cut off if your greeting is longer than 2 minutes. To exit the menu system, press Off. Make sure that the Answering system is on and your recorded greeting should play when you can't pick up the phone within the set number of rings.
Download a recording app for your cell phone
Play the recordings on your Panasonic and record them on your recording app/cell phone. Be sure to transfer or copy to another device also.
Test the recordings before you let loose of the old set.
To connect to the internet call the customer service number from your
mobile phone provider (eg.AT&T, Vodafone, 3, Telecom, Virgin etc.).
They will guide you step-by-step, giving you the correct settings.
