Karbonn K9 Logo
b
barenkumar Posted on Jun 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Call timer reset - Karbonn K9
Roger Walters
Level 2:
New Friend:
  • Expert 147 Answers
  • Posted on Jun 21, 2014
Roger Walters
Expert
Level 2:
New Friend:
Answers
147
Questions
0
Helped
41093
Points
370
Brief power outage. Light timer not working.
If there was a brief power outage and your light timer is not working, there are a few steps you can take to troubleshoot the issue:
  1. Check the timer settings: Make sure that the timer is set correctly and that the time and program settings are accurate. If the timer has lost power, it may have reset and will need to be reprogrammed.
  2. Check the power source: Ensure that the timer is receiving power by checking the outlet or circuit breaker that it is plugged into. If the outlet or breaker has tripped, reset it and try again.
  3. Check the timer battery: If your timer has a battery backup, check the battery to make sure it is still functional. If the battery has died, replace it with a new one.
  4. Reset the timer: If none of the above steps have worked, try resetting the timer to its default settings. Refer to the user manual for instructions on how to reset the timer.
If the above steps do not resolve the issue, it's possible that the timer has been damaged due to the power outage. In this case, you may need to replace the timer or seek the assistance of an electrician to diagnose and repair the problem.
How do I reset Woods 59017 mechanical timer
There is no reset for 59017 timer.
Check if slide switch is set on timer
If timer is not rotating, then check circuit breaker, check wiring, replace timer.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#in-wall
http://waterheatertimer.org/Woods-timers-and-manuals.html#59017
http://waterheatertimer.org/How-to-wire-timers.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Pushed reset button and will not respond. Red on light stays on
11/6/12
Copy following link for Utilitec LW60418 timer.
Same as Westek TMDW10, and Stanley 30418
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer is reset with one-button.
Unlike some timers that require 2 button push.
Push in reset button firmly with paper clip, and hold for several seconds. Repeat.
This action will clear timer memory.
If reset does not restore functionality, then timer could be bad.
This timer has 1 year limited warranty.
Suggest buying new timer at Lowes, and returning defect timer in new package.
When i unplug the timer then reset a new time schedule and plug timer back into wall my timer sets to 88:88. whats am i doing wrong? this timer worked brilliantly until i reset and plugged it back in.
Open following link to identify timer and read instructions:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Timers go bad for many unprovoked reasons.
Check outlet with circuit analyzer.
Extended warranty: If timer is defective, then buy new one from Target or Lowes, and return defective timer in new package.
To review:
Replace AA battery if this model has a battery carriage. Otherwise timer has internal rechargeable battery.
Press reset button with paper clip for a few seconds.
88:88-88 will flash on screen momentarily, and then 12:00 am will display. Timer is ready for programming.
If 88:88-88 does not roll over into the 12:00 am display, try resetting again.
If timer will not hold new programming, and keeps resetting, then see if reset button is stuck.
If timer does not reset and re-program correctly, then timer has gone bad.
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
We have a noma inside timer program and have no mamual for it and cannot seem to have it come on
Timer is not identified:
Look at following options:
Noma brand is old Intermatic brand that is sometimes/usually associated with Woods, but is also be used by various sellers to denote they are marketing a timer.
1) Add a comment and describe timer in detail, and/or post a photo of timer on Flicker and add a comment with link to photo.
2) Open following link to identify same-similar timer and download possible manual
3) If timer will not operate, last step troubleshoot is to reset timer.
Most plug-in timers have reset button. Press reset button and see if timer display is restored.
Some timers require additional button pushed along with reset button, some timers require 2 buttons pushed to reset timer.
Some timers have a batter that needs to be replaced. Replace battery and reset timer.
If functionality is not restored after reset, then check outlet for power. Test outlet with circuit analyzer.
If outlet is good and if functionality is not restored, then timer has gone bad.
Sunset sunrise doesn't seem to work anymore
Timer is not identified.
If digital timer does not function as before, try resetting timer and then re-program.
If timer has battery, then change battery and reset timer.
If reset does not restore functionality, then timer has gone bad. Most in-wall timers have 1 year limited warranty.
Below are common 7-day timers, but there are many different brands:
You posted under Woods 7-day timer: except Woods timer does not astronomic dawn dusk function. Woods 7-day is same as Tork 7-day and GE 7-day, and they do not have astronomic function.
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Reset button is small round button.
Push in reset with toothpick or paper clip.
Then reprogram timer.
If you have Intermatic ST01C or EJ500 battery operated timer: Replace battery, then to reset timer: push-and-hold ON_OFF button, and then push reset button. Keep holding on-off button until display changes. Release on-off button and display will flash 12:00. Then reprogram timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If you have Utilitec astronomic timer, then press reset button and reprogram:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
1helpful
HAVE intermatic timer for indoors.. battery seems ok, all of a sudden it does NOT turn lights on and off. I checked bulb in lamp it is ok.. when i do the Manual on and off from the timer it does NOT turn...
Manual override not working implies that battery is dead, not making contact, or timer has malfunctioned.
Battery operated timers can be reset depending on timer: removing battery will reset some timers, other timers have a reset button, other require another button held down same time as reset is pushed.
If functionality is not restored by reset, then timer has gone bad.
Some Intermatic timers appear on following page, with instruction manuals for many of the timers shown. You can add a comment about specific timer:
I need to know how to reset the timer
If you reset ST01C timer using reset button, then all programs are lost, plus current time of day.
Generally this timer needs to be reset if error message appears and as last resort for troubleshooting problem. Timer does not need to be reset after battery goes bad, all you do is set current time of day, and then program remain inside timer indefinitely (or until timer is reset of goes bad)
If setting current time of day does not work, you use reset button.
For ez programming steps with illustrations:
http://waterheatertimer.org/ST01C-program.html
How to reset ST01C using reset button:
Push and hold ON-OFF button and then push reset button using toothpick or paperclip.
Release reset button but keep holding ON-OFF button until INIT displays.
Then release ON-OFF and 12:00 should be flashing.
If timer functionality does not restore, then try replacing timer battery.
If functionality will not restore, then timer is bad.
This timer does not need electric current for setting timer, so timer display is not dependent on circuit breaker.
If you have a different timer, then add a comment with in-focus photo of timer for possible identification. Most other timers do not require 2-button reset procedure.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
I have a digital wall timer that allows for settings over multiple days. Trued to reset it (remove a few memorized settings) by pushing 'reset'; but this had no effect. Do I need to press it for a longer...
You posted the question under ST01C timer.
This timer will clear all programs if you hold reset in for a few seconds until the screen starts blinking 12:00. The reset button is a small round button that you push with a paper clip.
The ST01C memory for current day can be cleared by removing battery for a couple minutes, but the day-to-day programming remains forever until timer is reset.
Each timer tends to follow the same pattern as described above when there is a small round reset that is pushed with a paper clip >> push, hold for a few seconds, timer resets.
Other timers have a larger button for Reset ... the timers with larger reset button usually require you to hold the clock button and reset button at the same time ... or some other button besides clock has to be pushed at same time with reset. You can try different combinations of buttons and hold both down for a few seconds.
If you reply to this response with your exact model and brand timer, I can look up the specifics for most timers
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Top Karbonn Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Karbonn Cell Phone Expert? Answer questions, earn points and help others
