Panasonic Home Theater System System Logo
A
Anonymous Posted on Aug 24, 2017
Would you know the best connections to connect a Panasonic Sound Surround (SC-BTT290)/ Panasonic TV (TX-L42ET5B) / FreeSat (Humax HDR1000S.I am using Digital connection from FreeSat to Sound Surround. BlueRay is great but need sound turned right up on TV and FreeSat. Also when I switch TV to Input = TV I get the TV picture but sound I hear is from FreeSat box.
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Aug 31, 2007
SOURCE: Trying to connect Surround sound system with 3 Other Components!?
What you have to do is to connected the Direct TV receiver and the Panasonic VCR directly to the TV set. This way when you go to the input on the TV set that this equipment is hooked to, the sound then comes out of the TV set and goes into the surround system through the cable you have coming out of the TV set marked TV out to TV audio input to the surround sound. This surround sound only has a line output, a tape output, and an aux. input. You have only one input to this surround sound unit. You should have at least two separate video and audio inputs on the TV set to use for your other equipment, and to use the other equipment through the surround sound, you simply leave the setting on the surround sound on the TV mode and and switch the different inputs on the TV set. Good Luck
foamesh
  • 7 Answers
  • Posted on Jan 29, 2008
SOURCE: CONNECTING THE PANASONIC SC HT680 TO A SONY TRINITRON COLOR TV AND CABLE BOX
audio/video OUT from the cable box to the aux IN on the panasonic right? So you can see the output from the cable box but only sound from dvd. Are you changing the input on the tv when you go from watching the cable box to watching the DVD? the panasonic handles audio, but the video from each goes to two different inputs on the sony. I hope none of this sounds condescending.
Anonymous
  • Posted on Dec 17, 2008
SOURCE: cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Anonymous
  • Posted on Aug 27, 2009
SOURCE: Panasonic SC-HT900-problems with surround sound mode and digital input
I have the same problem with my RCN system
fahadn
  • 21 Answers
  • Posted on Sep 14, 2009
SOURCE: No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
2answers
hi, you need to have 3 pair of audio-in ports for that. i think your sound system has 3 input ports. ie, 1.tv in ->u can connect this to audio out of your tv 2: vcr in ->u can connect this to audio out port of vcr 3: aux in -> this can be connected to your TV Receiver then you can use the soundsystem remote to switch between the source to listen one at a time. pls come back if u have any thing more sreejith
How to connect my hdtv to surround for audio
It looks like from my searching you have an optical link on your tv and your reciver. You should just have to choose that as your output on the tv and your input on the reciver. It should be labled something like spdif. In my opinion it is the best cable ever until hdmi came out now its still really good.
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
Connecting Panasonic SC-PT550 to TX-L42E5B
I have a pansonic tv that i brougt last winter ,All you have to do to get audio from it is use a optical cable,
My surround sound will not work through the TV, only the DVD
If your tv and surround has an optical input/output.Then you can connect with an optical lead.This will then play the sound from whatever you are watching.You normaly select dig1 or input1 on the surround system.
2answers
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Panasonic multi connections
HDMI audio in this setup is a one way street. Audio will not come back from the TV to the audio system.
Sorry as you have not shown the model number I can not advise on the system fully.
However, it is standard on the current Panasonics to use Optical audio as a return feed or phonos.
Optical would be best as it carries full digital surround, whilst the phonos only carry "surround"
It may help for you to look a the new Panasonic web sit as there is now an interactive "How to connect your system"
PanamanNE
Sound Quality
Preferential Quality Connections in order of higher quality are: 1st>HDMI, 2nd>DVI, 3rd>Component/S-Video, 4th>Composite Video. Make sure you only use the surround setting on 1 of the 2 components, which ever is of better quality. If you use them both it WILL sound like mud. (older receiver-newer tv>probably tv) but you must connect all tv audio channel outputs to receiver. (newer receiver-older tv>receiver would be better)
Receivers also tend to have more wattage to drive larger speaker loads than most TVs. The key is to turn off the surround and SRS functions on the TV if you use the surround decoders on the receiver. Either way you use it, make sure you use the set-up feature to balance the outputs of the various channels for either source (the levels of the two will probably be very different).
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
