Need torque spec for bolts when replacing drivebelt for harley davison dyna low rider
SOURCE: torque specs for cam on 2006 honda crf250r
Rock the caps around to make sure the bearing locating clips are lined up. Torque the bearing caps to 12 foot-pounds. At this point you must check the valve clearances again. If any are off, the cam must be removed and the correct shims installed.
Please rate this solution. Thanks!
SOURCE: need torque specs
General spec is 8 ft lbs. 16 ft lbs then 90 deg turn. the pattern is the key. follow the pattern in the manual
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_5bac37c3cb991fdb
SOURCE: torque specs for derby , inspection cover, &
what is the torque specs for a derby cover on my 2009 Soft tail?
SOURCE: 93 Dyna low rider fork oil.
your local hd shop should be able to answer this for you as its a mesured amount and to much or too little will make the bike not handle right
SOURCE: Need the torque specs on clutch for a 85 FLHTC
The torque specs are the same as with any Evolution engine. The compensator sprocket 150-165 foot pounds.
Clutch hub nut (left handed threads) 60-80 foot pounds.
Use Loctite 271 on threads. Two lines in nut on Compensator and one line in clutch hub nut.
