I would like to program the CO button with a different extension number.
SOURCE: kx-t7630 product spport
This is how I did it:
1. Press the 'Program' button
2. Then dial ** (star, star)
3. Enter the password (usually 1234)
4. Press 'Next' until you get to 'Ext Name'
5. Press 'Enter'
6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is)
7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters.
8. Press 'Enter' then you are all done... pick and hang up the handset.
SOURCE: need to program pf buttons on kx-t7730
Press Program Button
Press Button to be Programmed
Dial 1 - Plus extention number to be stored on button
Press button directly under 'ENTER'
SOURCE: Panasonic phone KX - T7630 - memory
Of course it's possible. Maybe the PROG softkey is a start. That an a manual.....
Carl
SOURCE: How do I change the name display on my extensions
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
SOURCE: how to forward calls to
From the intercom dial *710x ext and # where X is 2/3/4/5 for All,Busy,No Answer,Busy/No Answer. There are some other conditions and Do Not Disturb in the dialing string (and 0 cancels) but that's the basic.
You might want to review the Operations Manual (OM) under Call Forwarding to see the complete instructions.
Carl
