This is a solenoid controlled deck. INITIALLY I'd say your rewind button is stuck in the pushed position. sometimes dirt, grease, smoke narrow the clearance between the buttons. THEN I'd say the relay that controls the solenoid is stuck in the engaged position. THIRDLY I say the solenoid ITSELF has some metal filings or dirt in IT, and it is jammed. Let me know
SOURCE: Tascam 202 Mk111
most all twin well machines will play off one deck and record to the other.
using an outboard mic preamp will allow for less noise using the sm57. balanced mic cable with 3 pin xlr/cannon connections also reduce noise.
SOURCE: right side deck problem Tascam 302MKII
That part number was 095-3M002870. Some how I did not get the M in there..
SOURCE: tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
SOURCE: Tape reel on either deck stops and tape gets
Try replacing the belt, because when the belt is a bit old it looses its elasticity and it can't drive the whole thing properly.Tape A and Tape B works independently.
