Heating & Cooling Logo
v
vijay Posted on Jun 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does error e4 mean in onida sm18 slm? - Heating & Cooling
jerry howell
Level 2:
Scholar:
New Friend:
  • Expert 183 Answers
  • Posted on Jun 05, 2014
jerry howell
Expert
Level 2:
Scholar:
New Friend:
Answers
183
Questions
0
Helped
31981
Points
330
Use google to find a manual or web resource for manufacturer's tech support
1helpful
I have a LOFRA dishwasher LOD6001/LOD60002W showing an E4 error. It started OVERFLOWING so I opened the door to turn it off. Now it will not restart.
"E4" means Error and from 1 to 5 means malfunction in water valve / sensor. E4 means defective water level sensor.
Sep 27, 2018 • Dishwashers
2helpful
2answers
My SoleusAir portable air conditioner has an "e4" code.
Here are the SoleusAir error codes...
e2 Room temperature outside of working range of unit (too cold).
e3 Faulty coils - Repairs needed.
e4 Internal frost in the unit - Defrost.
e5 General failure - repair needed.
e7 Reservoir full - Empty the reservoir.
If the unit is freezing up (frosting) you may want to check (clean / replace) the filters.
E4 error code beautyrest electric blanket
beauty rest electric blanket error code - akaQA
www.akaqa.com > Uncategorized
beauty rest electric blanket error code. What does error code E4 mean? Answer this. 0 Views: 2487 Answers: 1 Posted: 3 years ago. Comment this question.
E4 error code beautyrest electric blanket - Fixya
www.fixya.com/support/t22178587-e4_error_code_beautyrest_electric
Dec 13, 2013 - E4 error code beautyrest electric blanket One side works the other returns an "E4" error code - Simmons Beautyrest Microfleece question.
What means F1 error code in onida split ac
My onida inverter ac showing F1 error. Ac working but no cooling out door unit not working. Please find me a solution
3helpful
Error problem e9 in onida 5star split ac
what means of e9 error code in onida split ac ?
1helpful
Error code E4 Chigo air conditioner
What is the error code E4 on a chigo air conditioner?
When this error code appears, it means there is a problem with the hose pipe - the heat is being kept in the hose pipe and not being transferred properly.
Error Code: E4 - Units Abnormality Protection - Knowledgebase
1helpful
I have e4 showing
E4 error indicate an abnormal water level which means too much inlet water (E5 also is refer at this fault).
I quote other comments/solution about this same error:
I had the e4 error code and i took the outer panel off and inside behind the power button is a grey reservoir tank which measures the water that goes inside the dishwasher which actually got bunged up with **** and grease causing the floaty thing to get jammed and cause the e4 code to come on which means abnormal water level the top to the reservoir just unclips on both sides then just clean all the gooey stuff out and put it back together it worked for me.
Good luck.
3helpful
3answers
E4 Error
york hvac unit e4 error code Troubleshooting
Top Heating & Cooling Experts
Paul Carew
john h
