Speed adjust module appears to be not working. How do I wire around it, and just operate the sander at full speed?
SOURCE: Hand sander stops spinning once placed on item to be sanded
This sander has a brake pad that is supposed to stop the rotation when the sander is not actually in use. It sounds like it's malfunctioning.
The only other thing I can think could be a cause of what you describe is an improperly assembled sanding base. Have you changed out the base, and if so, were you sure to properly align the replaced base on the machine before you tightened the allen screw?
If you're not comfortable disassembling a tool that is still under warranty ( I think it's two years for that one), I would recommend finding a Dewalt service center and taking it in for a factory service call.
SOURCE: need a wiring diagram for a delta drum sander
Here's a link to the online manual.
As far as that diagram....didn't you label the wires?
Take a look here, it may help you. circuit wiring , especially the paragraph that begins: "Knowing that electrically common points have zero voltage drop between them is a valuable troubleshooting principle." Also read about resistors. That speed control knob is one.
Hope that helps...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
SOURCE: Sander will operate only at a very low level of power.
It is either a bearing or bearings that are failing and causing the sander to slow down or the variable speed switch is failing.
SOURCE: electric sander sparks and smokes - does not run
its possible that the electric motor brush is already worn out. try to have it changed..
SOURCE: Dewalt DW433 belt sander stop working, why?
Check the brushes for the motor they may have gone bad or broken, I have seen this happen before on dewalt tools.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
