20 Most Recent Dewalt DW411 quarter - sheet palm grip sander with dust collection Questions & Answers
The answer "Go to Dewaltservicenet" can be confusing - the actual site is servicenet.dewalt.com and even then, entering your part to get to manual can be infuriating. This is the link for the current model which, for all intents and purposes, is the same. The link to the helpful page is: http://www.dewalt.com/tools/woodworking-sanders-orbital-sanders-d26441k.aspx . You'll get a pop-up box with a dropdown that has a few numbers, nothing else. Just click on "1" and ignore language that indicates that this model has more than one - it does not. After you click on "1", the pop-up disappears that you're on the d/l page. Downloads are in the upper right corner. You want "Instruction Manual".You should get to this page: http://servicenet.dewalt.com/Parts/Browse#6229 but may not, it's very glitchy. On this page, you'll want to make sure "Sanders" is on the left and "sheet" is on the right. If you try to get the Manual from the DW411 page, a blank page will open. Make sure your pop-up blocker is off or that you allow dewalt.com. The instructions for the d26441k are identical to the dw411 - same technique for loading sanding sheets, same rods, etc. I've uploaded the d26441k page manual .pdf so that should help. It's easy to get lost on the Dewalt site while trying to find somthing so simple. :)
Dewalt DW411... | Answered on Dec 14, 2014
Yes it can be replaced. If you go to www.ereplacementparts.com, you can look up your sander and find the parts you need. You can buy the parts there or get the part numbers and search the web for pricing.
Dewalt DW411... | Answered on Dec 04, 2012
Dewalt is not going to make an accessory for you to do so, since that sander was designed to use 1/4 sheet sandpaper, and therefore takes standard paper clamped in place. You could make your own base for the sander out of thin plywood or some other suitable material, covered perhaps with a laminate or rubber surface, that would accept PSA (pressure sensitive adhesive) sandpaper, which you can buy in rolls appropriately sized for your sander. Or you can try some kind of after-market conversion kit such as this one (See also here, etc.)
If you really want a hook and loop base on your sander, I recommend you bite the bullet and simply purchase a random orbital sander with a H&L pad. Then you'll of course have to buy the perforated paper discs to go with it....
But you'll easily be able to change grits, and the performance and quality of your sanding will improve.
You might check the reviews in various woodworking magazines before you make a purchase, just so you know what you're likely to get for your money. There's a vast array of machines made, and the quality varies accordingly, and depends to some extent on your budget and intended use.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Dewalt DW411... | Answered on Dec 21, 2010
are you putting holes in the papper with the guide? there has to be holes in the paper for the dust collection to work
Dewalt DW411... | Answered on Oct 15, 2010
go to Dewaltservicenet.com and in the midle of the page and towards the bottom under need manual type in your model number and you should be able to download anbreakdown and operators manual
Dewalt DW411... | Answered on Oct 05, 2010
best way is go to dewaltservicenet.com and they have a service/repair center locator section type in your information and you can find one pretty close that way. Also you can download a schematic for the tool while you are there.
Dewalt DW411... | Answered on Sep 25, 2010
Sometimes they do get stuck and you will need some other measure to open it, may need to use a vice and/or hammer,or a big plier...But this means also that it needs a bit of oil in it just to break the dirt causing this to stuck..You may need to give it a few shock with a hammer,not to break it but enough for the shock on it...This normally works..
Dewalt DW411... | Answered on Aug 04, 2009
The nailer must be firmly pressed against the surface you are planning to nail. This will arm the nailer in preparation for firing the nail.
Dewalt Tools &... | Answered on Oct 03, 2019
Try this link:
https://www.ereplacementparts.com/dewalt-dw423-type-inch-evs-random-orbit-sander-parts-c-1009_2742_2758.html
Dewalt Tools &... | Answered on Apr 02, 2019
no, but there may be an overload fuse. My guess is that it is part 62 here, but not available. Take it to a DeWalt service centre
https://www.ereplacementparts.com/dewalt-dw431-type-electric-belt-sander-parts-c-1009_2742_2764.html
It is available here, but is $88. Lot of money to lay out on a guess, which is all the more reason to get it looked at professionally. It may also be the motor windings burned out.
https://www.toolpartsdirect.com/dewalt-dw431-type-5-electric-belt-sander.html
Dewalt Tools &... | Answered on Feb 27, 2019
Dewalt DW411 quarter - sheet palm grip sander with dust collection Logo
9 questions posted
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Dewalt Tools & Hardware - Others
Most Popular Question
palm sander
  • Tools & Hardware - Others
