Washing Machines Logo
K
Karl Posted on May 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wfs1071bd user manual
D & B Enterprises
Level 3:
  • Master 778 Answers
  • Posted on May 21, 2014
D & B Enterprises
Master
Level 3:
Answers
778
Questions
0
Helped
141742
Points
2135
Whirlpool wfs1071bd. This front loader has started leaking water from the detergent dispenser which runs down the front onto the floor. Do you suggest a solution to fix the problem?
Take the dispenser out you have probably chocked the outlet pipe with soap needs cleaned and also clean inside black dirt put it back and try hope this helps
My whirlpool 6th sense front loader has stopped whilst full of water, half way through a wash. Have emptied machine, Still no power, machine wont turn on.
Hello Janine Gooch,
Went out on our internet trying to find your trouble shooting guide (typically in the OWNERS MANUAL)...
Finally ended up in AU ... No luck.
(September 9th is only 6 hours old here (SF Bay area)).
Your local peers have NOTHING NICE to say about that machine... particularly the CONTROL BOARD:
Whirlpool WFS1071BD Question and Answers
Hope this helps (says top load... shows front)
Carnac the Magnificent
Whirlpool front loader WFS1071BD I'm trying to source a manual for this machine? The rubber ring that sits between the front door and the inner core has come off.
i use manualslib as u can get and share manuals at ManualsLib Makes it easy to find manuals online failing that search in address bar with model and no as many sites have free manuals but beware the ones that charge...lol
Hi, how do I clean the pump of the wfs1071bd front loader washing machine. Thanks
if there is no filter disconnect mach and carefully either take the back off if it comes off {some} dont or you could lay the mach down and gain access to the pump remove retaining screws and hoses and there you go remember power off before you touch anything.
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
18helpful
2answers
I have a whirlpool WFS1071BD. When we wash the red light comes on saying clean pump and i can not find the manual can you help me out. Cheers Mark
Hi and welcome to FixYa, I am Kelly.
This is the WFS1071AW version of the manual and the pump cleaning instructions are the same:
http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001
And then enter "WFS1071" Instructions for removing the filter are on page 14 of the user manual.
(Wth pictures)
Pump / Filter cleaning POWER OFF UNIT UNPLUGED:
Basically you open the lower panel by pushing down and pulling toward you at the top. Use something like a cake pan for catching water. Grasp the CIRCULAR filter and rotate it COUNTER CLOCKWISE until the water starts draining. WAIT until all the water possible drains. Then unscrew the filter and pull it out. Clean out any debris. Make sure to reach deep into the filter hole and CAREFULLY clean off the sensor if you can reach it and then reinstall the filter by rotating clockwise. Last steps install the lower panel and PLUG IN POWER.
Thanks for choosing FixYa,
Kelly
2helpful
Hi there I have a whirlpool wfs1071bd sometimes when it is washing it will leak out the door I only put a few clothes in is there something wrong
Check the door seal where it meets the door..If there is even a small split it can leak....If damaged it should be replaced...Good luck....Nomess
6helpful
2answers
I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
Top Washing Machines Experts
john h
