SOURCE: How do I fix a
Here's how you set the timing od the Machine alright:
1. Take the side plate off, take the needle plate off.
2. Take the presser foot off, and put a new needle in the machine. 3. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
4. Then, turn the handwheel toward you until the top line is where the bottom line was.
At this point, the tip of the hook should be directly in the scarf of the needle.
This should set the timing of the machine perfect....
SOURCE: bobbin case is popping out, and machine is birdnesting
Usually when this happens the bobbin is in wrong, replace it make sure the thread is going out the right way, make sure there is no lint or small pieces of thread around or underneath the bobbin area. Make sure you thread it with the foot up. Also make sure you are usng the right bobbin for the machine. They can easy get mxed up.
SOURCE: singer 7426 timing off
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Testimonial: "very helpful...thank you"
SOURCE: Singer futura 250. while sewing the E4 code
Are you using bobbin thread? Is your thead new? Is themachine threaded correctly?
Make sure that when you thread the upper part the thread go under the circle that pull it.
Another thing is that when you hit the start button, pull the upper thread until the machine goes two or three times. It helps the bobbin thread to come up and the machine start sewing.I you leave it along the thread sometimes doesnot comes up and that is why the machine beeps.
I use this technique to make sure it doesnt beep and to cut the thread (the one at the beginning so it doesn't mess my design)
SOURCE: singer futura beeping every 8 stitches can you
Make sure your thread goes under the plate of the carrousel. If not the machine think is not threaded and it beeps. Thread the machine with your left hand and Pull the thread with your other hand to make sure it "clicks" to every part of the machine.
Another important detail is to add thread nets to your spool. After some used the tension of the machine is affected and the nets help the slippery thread to be pulled by the machine correctly and avoiding the beeping.
