Black & Decker Cst2000 12 - Volt Cordless Grass Hog 12" Trimmer/Edger with Auto Feed Spool Afs Logo
M
Martin Dschaak Posted on May 18, 2014
How to replace battery in battery pack (need help with wiring layout)?
I have replacement battery, but I do not remember how the wiring unit goes in with the battery. I know I should have taken picture, but I didn't. Anyone have a picture of the battery and wiring in the batter pack?
1helpful
I have inherited a Rascal Fold and Go 370 and have ordered two new replacement batteries to go in the battery case......however, my husband does not remember how the batteries are wired back in the ca
the batteries are wired in series, meaning two 6volt packs are wired nose to tail so they can deliver a full charge, OR they are wired so that both are in parallel, and each pack contains 1 Ampere-Hour of energy at 12 VOLTS and you use 2 packs to get 2 Ampere-Hours of "CHARGE". What your significant other has to get before he connects the wires back up , is a VOLTage METER to verify the polarity of the wires coming from the adaptor. It USUALLY is RED for positive, BLACK for negative........ but not always....... measure to be sure, then double check.
IF it is two 6 volt cells that are connected in Series, then the red of the first pack goes to the RED WIRE of the adaptor, then the BLACK WIRE of the first cell goes to the RED WIRE of the second cell and the BLACK WIRE of the second goes to the BLACK WIRE of the adaptor.
*Your mileage may vary, not intended to give professional advice, all actions are at your risk, Federal Deposit Insurance will only cover cash deposits at Federal Registered Banks. Colours may fade over time. Always call a friend when you need the answer.
Rodeo fuel pump rewire
Usually on these it is the fuel pump sending unit. But here is how the wires connect. Here is what you need to do about the different wire colors. First disconnect your negative battery. Drop the fuel tank and replace pump. Remember to have a splice kit in hand. Ok now here is how you connect the different colored wires. Black goes with black. Gray goes with black and orange wire. Purple goes wit blue and yellow. And the last wires goes together. I hope this helps.
Number order for plug wires on a coil pack for a 1985 buick park avenue
Check this information about 1986 Buick Park Avenue 3.8 liter V-6 VIN "B"
Identifying Ignition Types I and II...
* On Type I coil packs, three twin tower ignition coils are combined into a single coil pack unit.
* On Type II coil packs, the coils can be replaced separately and the ignition wires are all on the same side of the coil pack.
With Type I Ignition
With Type II Ignition
Hope this helps (remember to rate this free answer with thumbs and leave some testimonial).
1helpful
Nos. 1 and 3 cylinders aren't firing and the code comes up as "system too rich Bank 2"
sounds like a bad coil pack, disconnect #1 then #3 plug wires from coil pack then start the engine you should have a good strong spark jumping to any ground around. if not replace the coil pack i don't remember which one goes to #1 & #3 but it's probably the passanger side. if this is the problem then the O2 sensor should read properly. disconnect the negative battery cable for a minuet then re-connect it which should clear the computer. if everythings good the light should remain off.
2answers
THE TIMER DOES NOT WORK , NEED TO REPLACE IT WHERE IS THE PART LIST FOR ML600TW MALIBU ANTS GOT INTO THE DIAL TRY TO CLEAN IT OUT APPENRENTLY BURN UP THE MOTOR IN THE TIMER LIGHTS OR ON ALL THE TIME.WORKS...
I've done a lot of reading and research on Malibu
No replacement parts for Power pack, or schematic >> Malibulights.com shows replacement lights and replacement power packs
Manual for Malibu 600 Watt power pack
SAVE the pins off old power pack and see if they match pins on new power pack ... because you can't find pins on the internet
When the power pack goes bad or you lose the pins, then you buy another power pack
Things to remember:
Match number of lights to power pack wattage
30 - 20 Watt bulbs => 30 x 20 = 600 Watt power pack
Replace bulbs as soon as they burn out, or other bulbs will burn out quickly, and I think it causes power pack to burn out sooner too.
Up-vote if this helped. Thanks for the feedback.
2helpful
Firing order for spark plugs and wires for 1992 Buick LeSabre
1992 Buick LeSabre 3.8 liter V-6 VIN "L"
Hope helps (remember rated and comment this).
5helpful
What is the firing order of the 3.8L engine in a 92 olds 88? Changing spark plug wires & must have switched order
1992 Oldsmobile Delta 88 3.8 liter V-6 VIN "L" - Identifying Ignition Types I and II
Hope helps (remember comment and rated this).
Reading number 3 cyl miss fire
Make sure the plug wires are correctly placed on the distributor cap (coil pack). In most cases, (when these are changed) two are accidentally switched.
Simply take two at a time and switch them. (refer to a repair maunal for firing order first). You can look this up online as well at http://www.google.com.
If these are correctly placed, then pull the wires (one at a time) from the plugs, and pull the plugs out and check for oil on the plug. If any one of these has oil, then you may have found your miss fire.
If all there is good (clean these and run truck); pull the distrubutor cap off (if equipped) and make sure the rotor (just under cap in center) is not cracked or warn (check end where small metal end is located). This sparks at each plug point on the distrubutor cap.
That is the next thing to check. On the inside of the cap. look to see that the prongs are not white, grooved, or broken. If any of these are true, replace both cap and rotor. Some rotors pull off, others have a small screw that hold them in palce which is located on the side.
If you're truck has coil pack(s) then have them all (if more than one) tested. These sit on a unit called a modular. Look at the modular after removing the packs and see that it is not bubbling, white, or melted. If any of these are true, it needs replaced as these cannot be tested.
Contact your local automotive parts store for correct parts and pricing. NOTE: some parts (seldom) may need to be purchased from dealer. This is rare, but sometimes an only option.
Also, if you have a distributor, check to make sure the coil wire (center of cap) is pushed on completely on the cap as well as the coil. (coil may need replaced as well) which also cannot be tested.
If need be, and you have not already, replace all of the following to ensure all is good:
plugs, plug wires, cap and rotor, coil, (the coil wire will come with the plug wires, but make sure when purchasing).
If coil packs are present instead of distributor, replace the following:
plugs, plug wires, any coil packs that are tested back, modular if it looks anything like that described above. Also remember to check for oil residue, or blackened powder on the spark plug ends.
If any, replace as necessary. When you replace spark plugs and wires do the following to ensure the firing order remains:
Pull one plug at a time. Take plug wire off the plug only, until new plug is inserted; then replace the appropriate length plug wire. (compare old to new; some may be close in length, but not exact as these are aftermarket plug wires).
Do this for each plug and wire. Save the coil wire for last to know you are finished with all: coil wire is the shortest of all (usually) and only goes on once way at each end: typically. One end will be straight - this goes to the coil. (not coil pack) the other end will be a 90 degree; this goes on the center port on the distributor.
If coil packs are present, there will not be a coil wire, as the coil packs replaced this unit.
My apologies for the lengthy reply, however this is to ensure you save time, money, and are aware of the different options and possibilities.
Please let me know if you need any further assistance.
carsandcomps
Guru, Premium Expert @ Fixya.com
1helpful
2answers
APC back-ups XS 800 battery backup : warning
Turn it off and unplug it from the wall.
Open it up and make sure that the red and black wires are connected.
If they are the battery needs to be replaced. They are only good for 2-3 years. If you are not comfortable with my instructions, call APC for free support. (800) 555-2725
Vote for this solution if it helps.
Top Black & Decker Garden Experts
Thomas Perkins
Thomas Perkins
Mike Cairns
Mike Cairns
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
