Hoover HTC243 Top Load Washer Logo
A
Anonymous Posted on May 13, 2014
Where is the filter on a hoover soft wave auto washer 1000
My hoover soft wave auto washer 1000 washing machine has a blocked filter I think, but I can not locate the filter.
1 Related Answer
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Nov 08, 2009
SOURCE: machine washes o.k. but does'nt spin
If you have not already done so, I suggest you remove the motor, and check the brushes for wear.
Please rate my solution.
Thanks.
I just need to know how to work the washer as i got one without a manual hoover soft wave auto washer 1000
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Hoover wash-dryer 110 soft wave It doesn't centrifugate. I would imagine that I have to clean the filter, but I cannot find the filter. Thank you beforehand for your help. Christina
hi christina,,,its dont centrifugate???????? hmmm! do you mean spin?
or it dose spin,,, but dont pump out? if its not spining there is a program fault,,,or motor fault,,,,if it dont pump out,,,thats a pump fault,, program fault or a blocked filter,,,the pump has its own motor,,,however if there is a program fault that could cause the pump to fale to pump as well???
my brain hurts now!
My hoover soft wave wash and dryer spins normally but will not drain. the hose is clear, also the waste pipe?
If you have not checked the filter, then you must do so, it is usually located at the bottom front left of washer.
If it has a screw in the handle, then undo the screw first, then unscrew anti-clockwise to remove and clean.
Thankyou.
Will wash but won't spin unless water syphoned off by draining through pipe into low bucket. So, the spin motor is ok, the pipe is not blocked... but the pump..... how can I get to clear out the pump?.......
Check to see if there is a filter located at the bottom front of washer behind plastic trim, if no filter, then remove rear panel of washer, and remove and check pump for blockage or malfunction.
Please rate my so9lution.
Thanks
2answers
Machine washes o.k. but does'nt spin dry (hoover soft wave auto - washer 1000 )
Thanks.
2answers
Washing machine wont go into full spin
was advised could be bushes so replased them works a treat thanks
Hoover VisionHD won't drain
This is joyce
I think you better check to see first of all if it is your pump,, that is the first thing to go.
thanks
joyce
4helpful
2answers
Instructions for Hoover Washer Time 160E
i have a hoover soft wave maxi 1600 7.5kg AAA it spins and empty's and sometimes it don't what could be the fault
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
