Watches Logo
A
Anonymous Posted on May 13, 2014
Set day and date? - Timberland Watches
2answers
Need to to set date and day on my Armitron 20/4591TT watch.
To set the date and day on your Armitron 20/4591TT watch, follow these steps:
  1. Press and hold the mode button until the display starts flashing.
  2. Use the hour and minute buttons to set the current time.
  3. Press and release the mode button to move to the date setting.
  4. Use the hour and minute buttons to set the current date.
  5. Press and release the mode button to move to the day setting.
  6. Use the hour and minute buttons to set the current day of the week.
  7. Press and release the mode button to exit the setting mode.
If you are having difficulty setting the date and day on your watch, you may want to consult the owner's manual for additional instructions.
tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 • Watches
tip
on Jul 09, 2010 • Watches
I have a omax quartz watch with day and date how do i set the day and date
How to set date and day in omax watch simple steps
May 23, 2012 • Watches
4helpful
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
7helpful
How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Jul 21, 2010 • Watches
4helpful
Bucherer Day/Date Setting Problem
You have to change day by the means of moving hands clockwise. Move as long as the desired day appears in window, then adjust the date and set time. Rate me, plz.
Mar 31, 2010 • Watches
3helpful
Adjusting day/date on a self winding Seiko, 7S2GB
mcdevito75 here, Your stem has 1 positions to set the date easily without haveing to cycle the watch 60 times. First pull the stem out to set the day, set the day 1 day before the day you want, next, push the crown back in, NOW! Slip a finger nail just under the crown from the back as there is more room, it may take some practice so be patiernt and gently, gently lift the crown to it"s first position, once in it"s first position turn the stem and see the DATE change, set the DATE to 1 DATE before the DATE you want, NOW pull the stem out to set the day date and time of day. Your watch is set and the day date will change on time, a little past mid nite.
Setting my day date on watch
mcdevito75 here, The stem has 2 positions, first, set the day to 1 day before the day you need, now, slip a finger nail just under the stem and gently, gently lift the crown to it;s first position, set the DATe to 1 date before the date you need. Push crown back in, now pull crown out to set the date and time of day. Your watch is set and should change around mid nite
2helpful
3answers
Setting the day and date
i am scared of putting to much force turning the crown
It is very hard or stiff ND CAN'T LIFT CROWN TO BR ABLE TO SET DATE AND TIME
Top Timberland Watches Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Timberland Watch Expert? Answer questions, earn points and help others
