Dacor ECS127 Epicure Stainless Steel Electric Single Oven Logo
A
Anonymous Posted on May 10, 2014
SWhy is my Sub Zero refrigerator icing on back interior wall
Jorgie the appliance guy
Level 3:
Top Expert:
  • Dacor Master 5,639 Answers
  • Posted on Mar 02, 2015
Dacor Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1523861
Points
32630
Probably a defrost terminator or defrost timer issue, check with multi meter, u may also have a bad heater element
Tapan Visualite wall gas oven will not heat. No glow either
Please check the associated fuse within your fuse box to see if it's blown out. Then, you can clean interior of oven in a manner recommended by the manufacturer before attempting to heat again.
Thank you.
Nov 10, 2022 • Ovens
Hi. I have a Frigidaire single wall oven ModelFEB27S5ABA The oven light is on . There is no reading on the control panel. this happen after i had my electrical sub panel rewired.
You have to check electricity coming to the oven. It is 3 wire coming to the oven. Red, white and black. Between red and black you should have 240V. Between white and red - 120V, between white and black - 120V.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 05, 2017 • Ovens
1helpful
Why is there a loud noise coming from control panel when I turn on the oven?
How often does it happen? Sounds like your control board is starting to fail. The Repair Shack can fix the oven control board if it needs repaired.
1helpful
I have a Frigidaire Gallery Refrigerator with bottom freezer that is only 3 yrs old. My problems are with the ice maker and the door seals. The ice maker in the top in the refrigerator makes ice but f
Thank you for your post, Genie Byrd!
From my understanding your Frigidaire refrigerator is not sealing properly which is causing an issue with your icemaker. You may need to replace the component for your seal. I would recommend having a professional technician out to your home to properly diagnosis and repair your refrigerator. Are you under warranty? Typically, if you are under warranty a repair should not come out of your pocket. I would consult with your manufacturer for warranty coverage. Hope this information helps. -OOS
Whirlpool 2000 generation plus
Check the power cord if the refrigerator does not operate. Plug it in if it was accidentally unplugged, or try another outlet if that appears to be the problem. Double-check the circuit breaker in your home to make sure it is powered on.
Inspect the refrigerator door if it doesn't completely close, or if it doesn't open easily. It could be that the bins or shelves are out of place, or certain food packages may keep the door open. Also, the gaskets of the door can get dirty over time, so clean them with soap and warm water.
Examine the temperature of the refrigerator. If it's too warm, then reset the temperature controls. Check the air vents inside the refrigerator to make sure they're not blocked. Readjust the temperature if items in some of the compartments are freezing.
Watch for trouble with the icemaker if your model has one. It may take at least one day for the refrigerator to produce ice, especially if you've just installed it. Connect the refrigerator to the household water supply and turn on the supply shutoff valve to get ice. If the ice is gray or has an unusual taste, install a water filter to flush out any minerals.
Fix the water dispenser if you can't pour a full glass of water. The refrigerator's water shutoff valve may be off or incorrectly installed. Wait 24 hours for the water to cool if you've just installed the refrigerator. The water temperature should be no more than 50 degrees F.
Mustang Parts.
May 28, 2012 • Ovens
MY GE refrigerator is freezing in the freezer section and the refrigerator. However, this is only at the bottom to slightly below the half way Mark. Thisis a two door refrigerator freezer. One half is...
Do not know how to find a repair in your area, but here is what is wrong:
The cooling coils, located behind the back wall of the freezer section, have frosted up, preventing the normal flow of air. Now, some of the cold air in the freezer is sinking and flowing into the bottom of the fresh foods section through the air vent by the bottom bin. To fix this, disconnect power to the refrigerator and unload the freezer side. Remove the panel at the back of the freezer section and melt all the frost and ice. Replace the heater at the bottom of the cooling coils, which would normally take care of the frost build up. Reassemble and restore power.
Maytag Model MTB2154ARW-water is appearing inside on the bottom of the refrigerator
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
My turbo chef owen sense somtime 208vac and some time 240vac
Hello. If you take the right side panel off, unplug first please. at the back is a blower motor, two screws on the back vertical rail, and one at the front edge of where it is connected to blow, probably under the foil tape, this will remove the blower. On the back wall toward the bottom, under all the relays, is a voltage transformer that tells the controller which voltage you have, replace it, and problem will be corrected. If you are not comfortable with this, call Turbo Chef for a local servicer, and call them to repair.
As for the F6 EC error, you are having a temperature problem due to the control area overheating, there is a blower on the back, and vents on the front, and side, either these are clogged, the fan grid is clogged, and the interior has alot of dust coating the interior of the right side, please unplug, vacuum, and clean out the dust etc.., after reassembly, after about 30 minutes of operation, the blower on the back should be on, if not you need another.
Hope that helps, and thank you.
Top Dacor Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Ngoro
Are you a Dacor Oven Expert? Answer questions, earn points and help others
