I would dry it completely and try it again. it may need to be opened and dried on the inside, or replace the joystick.
Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
SOURCE: How do I get the battery out of the wheel chair
Take the seat off and the batteries should lift out
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. [email protected]
SOURCE: I am painting and turned
hello,please rate me as in 1 to 4 thumbs up for my answer.im disabled myself & have a scooter.Im sure this Document will give ya all the info you need,download:troubleshooting_2007 SHOPRIDER.pdf
do that on the Adobe Reader,save or better still print & store in a polythene sleeve folder so you can keep for future.Type in your brouser shoprider.com & scroll down till you see the PDF File i have give ya,or visit:www.alldatasheet.com to download it.Hopefully you should be sorted,i know what its like to be without your wheels Colin.
SOURCE: how do i reset a jet 7 mobile wheelchair
did you put it in lockout accidentally? try this! turn off chair, press and hold the on button till a beep is heard, push and hold the joystick forward till a beep is heard, then pull back and hold joystick till beep is heard, turn off, and turn on. it should work now?
