I can not see how to put the new belt on my dryer is a haier dryer model number hdy61 can you help me
SOURCE: Replacing belt on Maytag Dryer (Model: LDE8626ACE)
This might be best handled by a technician as it is not a simple task for the untrained servicer. The belt should come with written instructions on replacement procedures if you desire to attempt it. We are factory trained to replace the belt entirely from the front, by feel only, as the idler pulley can't be seen. If you have a replacement belt but no instructions and wish to pursue this yourself, maybe our experts may be able to help you in our on line chat service, who can talk you through it, live. There is fee for this service but it is much cheaper than paying for a house call.
SOURCE: How to open the dryer and replace the belt
all dryers open from the top so open the dryer door and look inside the top edge you will see two screws . remove the screws and lift the top panel . the front panel has two screws on the top one on the left and one on the right remove them both and lift up the front panel to remove it. the only way you can install the new belt is removeing the front panel because the belt goes around the drum from the front. once you remove the old belt out put the new one in . the belt goes around the drum from the front and then to the motor and idle roller . you can reach the idle roller from the front left corner or from the back of the dyer? i like to install them from the back cause its more easy. in the back of the dyer where the hose goes connected to the blower is the top with four screws remove the hose from the blower tube and remove the four screws. after you remove everything you should be able to see the dryer motor and idle rooler put the belt over the motor first then over the idle rooler .always make sure when you do this the dyer is unpluged and after your done plug it back and turn it on to make sure it runs correctly . if it runs ok put everything back together again.
SOURCE: Replacing dryer belt on Maytag
i would take off the cover, it might be reg or star type screws and look at this page
http://www.partselect.com/ModelFrames.aspx?ModelID=64957&ModelNum=DG410&mfgModelNum=&ManufactureID=1&Selected=36056&Position=6&mfg=Maytag&Type=&Mark=6
SOURCE: replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
SOURCE: dryer belt broke on my dryer.
I use a putty knife to press against the spring clips to pop the top. Then I use a quarter inch nutdriver to remove the screws holding the front panel on. I remove the wires from the door switch and lift out the front panel. I remove the drum and put the dryer on a work bench or a tailgate. I inspect the blower wheel(most of the time they get loose). I get the ball of lint out of the front panel filter housing. I vacuum out the dryer with my shopvac. I oil the rollers and idler and inspect the drum slides for wear. I loop a new belt rib side down to the drum and set it back in the dryer. With my left hand I drop the belt under the motor pulley and raise up the idler looping the belt on it and let the tension hold the idler. I manually slowly turn the drum to make sure the belt is secure and not twisted. I place the front back on. Snap the top down and give her a try. Piece of cake.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
