Televison & Video Logo
A
Anonymous Posted on May 04, 2014
Xfinity remote codes tv
I need a xfinity remote code for a vizio tv
Scott P
Level 3:
  • Master 1,087 Answers
  • Posted on Apr 03, 2015
Scott P
Master
Level 3:
Answers
1087
Questions
Helped
262669
Points
2538
1 Related Answer
MHDISHNET
Mike.H-DISH_Network
  • 246 Answers
  • Posted on Jun 16, 2011
SOURCE: what are the vizio tv
Hey perlhoff,I see you need the remote codes for your Vizio TV. The codes are; 627, 505,506, 006, 527, 625, 110, 775, 756, 885, 864, 758, 111, 112 and 000. I will senda link to help with steps to do the Power Scan, http://www.dishnetwork.com/SupportSection/power-scan-instructions.
Need universal remote for NADC720BEE
Question edited for clarity.
No one buys Universal Remotes these days, they are so 1980! You buy a Facsimile Remote, an exact copy of the original like this one.
https://www.remotes.net/products/replacement-remote-for-nad-c720bee
https://www.google.com/search?q=remote+for+NADC720BEE
How to program a AVOL tv to a universal remote not in book
AVOL 4 digit codes:
2735 1820 3382 2051 2397 3118
AVOL 5 digit codes:
13118 13382 13479 12735 12051 12397 12278 11531
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
10812
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > https://www.xfinity.com/support/remotes/ Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
3answers
The codes for a sansai 501A universal remote
I have had very good luck with this site:
http://codesforuniversalremotes.com/
Need codes for my comcast remote
Comcast Remote Codes ' Program Your Remote Control
https://customer.xfinity.com/remotes/
Help and support with your XFINITY® Remote, select your remote control type and get the support you need to enjoy your XFINITY® TV!‎Comcast - ‎Find Your Comcast Remote ... - ‎Control Multiple Devices with a ...
Remote Control Help and Support ' XFINITY® by Comcast
2answers
Code for programming to a LG 4K tv?
  1. LG UHD 4K Television - LG.com‎
    Adwww.lg.com/UltraHD4KTVRatings:Reliability 9.5/10 - Picture quality 9.5/10 - Features 9.5/10
Search Results
    Find Your Comcast Remote Control Programming Code
    customer.xfinity.com/...tv/finding-your-remote-control-programming-co...
    Learn Comcast remote codes and more information on how to program your remote control. ... To Watch On Demand Programming with XFINITY TV:.
    DIRECTV - Remote Control Code Lookup
Vizio led tv ,xfinity remote doesnt control audio?
Set it up with an other code said for vizio. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Search the sites by type in the brand name to your device, in its search box. It will help you to find the document easily.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
4answers
I need a comcast remote tv code for a AMP'D tv
For the comcast xfinity remote use the philips code 11454 from the lcd tv section. That is the code that I got to work
5helpful
2answers
Nuvision tv remote codes for xfinity remote
NVU55FX10LS use 10690 Comcast / Xfinity SILVER Remote with RED enter button
Top Comcast Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Are you a Comcast Televison and Video Expert? Answer questions, earn points and help others
