The copier was successfully added to the network. I am able to print but I get the above error when attempting to scan.
Lift the lid as if you are going to make a copy of a document.. then whith the lid up turn the printer off still with the lid up turn the printer on and watch the scan lamp .. the light that moves when you make a copy. Verify that it lights up and moves back and forth. If it does not move back and forth the scanner lock may be in the locked position.. let me know
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
This sounds like a Scanner/Flatbed Problem. This series of printers have a known problem
with this component. The scanner is failing to initialize itself. The scanner
does need to be changed by an Authorized HP Warranty Repair Facility. It is
possible that it may be covered under an HP Extended Warranty program. See
repair information VIA posted Link.
Cheers!!
Cheers!!
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well, Printer Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook. You may receive some communication error messages if you are using a "PORT REPLICATOR CABLE"( USB TO PARALLEL connector). The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at [email protected] if you need further assistance.
Bye.
