Pushing the letters and buttons on the left side of the screen takes me to other letters than what I want, and functions other than what I need.
For anyone who has the machine and may have lost the manual here are some links for a new manual
http://www.sewingpartsonline.com/instruction-manual-singer-xl1000.aspx
Singer Model Quantum XL 1000 Instruction Manual Singer Sewing Machine...
SOURCE: My Singer Quantum XL 1000 is jammed and does not
Try to turn the hand wheel (on the right side of the machine) backwards ( if you are facing the right side of your machine, turn it clockwise) and try to remove the thread. Once its freed up, change the needle.
Hope that helps,
Chris
SOURCE: The LCD Touch-Screen not working
Hi-
Chances are you need to reset the settings. check the guides as well for the correct setup.
Hope this helps
SOURCE: How do you recalibrate the touch screen on the
Enter service mode....
Press the start/stop switch and hold it while you power the machine on.
THEN, press the reverse switch, hold it and press the lcd. Release the reverse switch AFTER you touch the LCD.
SOURCE: Singer Quantum XL 1000 LCD Screen
Hi jlbostwick,
Here's what you can do to recalibrate the touchscreen of your machine:
Enter service mode.
1.Press the start/stop switch and hold it while you power the machine on.
2. Then, press the reverse switch, hold it and press the LCD.
3. Release the reverse switch AFTER you touch the LCD.
Hope this helps.
Thank you for using FixYa.
SOURCE: I had my quantum xl 1000 sewing machine repaired.
The same Problem has my XL-1000, only with me everything is in Dutch. In the Service Manual, it is not described how you could change the language.
